Power Amp Stands
gudnoyez
gudnoyez Posts: 8,179
edited July 2014 in Electronics
Looking for a place to buy a Amp Stand an inexpensive one at that, say one around 200 bucks if something exits in that price range. I was wondering if cutting a sheet of plywood the size of the amp would work and what to use for isolation feet. Leads anyone?
Post edited by gudnoyez on
  • voltz
    voltz Posts: 5,384
    edited July 2014
    Audio Advisor has some to look at! I buy a lot of stuff from them.
    http://www.audioadvisor.com/Amp-Floor-Stands/products/37/
    The black one has our Adcom 5503 sitting on it LOL!
    edited July 2014
    voltz wrote: »
    It appears that that black sanus is the way to go you got a 5503 sitting on yours the picture of the one in the display has a 5503 on it a d that's what I'm looking to put my 5503 on. Let me ask you this does it have spikes? I put down a floating floor system it's tile on a plastic frame carpeted it's raised off the concrete floor an inch with that weight spikes would go through it unless I put hockey pucks under the spikes what do you think?
  • Mikey081057
    Mikey081057 Posts: 7,127
    edited July 2014
    The VTI stuff is nice as is Lovan
    I think you can find them on Amazon.
    Garage | Polk Monitor 5B's
  • voltz
    voltz Posts: 5,384
    edited July 2014
    I don't have one yet! I just meant in the picture on there web site it looked like it was the 5503 in the pic. as I knew you & I both had the 5503 amp.
    just check the manual and it does have spikes & plastic feet included.
    But I think your right about the combination of the amps weight & the spikes could be a problem for you. you may want these little disc under the spikes. or just use the other feet which I think are height adjustable.
    edited July 2014
    Hey thanks found it on Amazon for $66 free shipping thanks voltz you came through for me :)
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited July 2014
    I have used the Sanus Euro stands for about 8 years now and will be ordering a couple more to go on either side for amp stands. They are rugged, well built and easy to clean with a nice matte black surface that resists marring too. They have nice discs on the rails to protect floors.
    edited July 2014
    My Sanus Euro amp stand showed up today man Amazon is fast. I would of loved seeing it drone delivered but fast enough for me thanks for all the suggestions everyone!
  • voltz
    voltz Posts: 5,384
    edited July 2014
    How are they working out for you? and have you got all of your equipment hook up now?
