I need more power
dearold_dad
dearold_dad Posts: 6
edited July 2014 in Electronics
i need more power i have a pioneer SVX-D710S , center h&k 125c, 4 rti8 for fronts and klipsch rb5 II for souround, sub onki oskw-530 with upgraded dayton speaker, using swell 12 awg 259 silverback speaker wire. Please help me i dont like change i love my pioneer cause it is very reliable and sounds great but as you can see more power is needed
Post edited by dearold_dad on
    edited July 2014
    So what help are you asking for ? Amp recommendations ? If so, B&k or Parasound amps match up well with Polks. Just make sure the receiver has pre-outs to add an amp.
  • cfrizz
    cfrizz Posts: 13,415
    edited July 2014
    Welcome to Club Polk, but I hate to tell you that the only way you will be able to get more power is to upgrade to a receiver that has preouts for a separate amp which yours doesn't have. Once you upgrade your receiver, then you will be able to get a separate amp to show you what your speakers can really do.
  • GlennDog
    GlennDog Posts: 3,158
    edited July 2014
    ^^^ this ^^^
    Welcome to CP! Where are you located?
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • dearold_dad
    edited July 2014
    i was looking for a new receiver but ive been overloaded with reviews and specs when i purchased my pioneer i just got the best they had 16 years ago . im in utah, i have 500sf to fill with sound, i want a receiver that will push all the speakers with the same power (not like movies dts dolby digital)but i still want that option, thanks guys for the replys. signed confused
    edited July 2014
    If you like the Pioneer sound, then stick with it. I'd suggest one of their higher end models though like the SC versions. Plus they will all have HDMI connections, better dacs, and ice amps which will hold their power better over 7 channels driven than their counterparts.
  • dearold_dad
    edited July 2014
    so i won't be beter off with a brand other than a pioneer all the systems ive looked at dont drive hard for music and movies the 5.1 and 7.1 configuration is as expected . if im geting the advice you all are offering is new receiver and also amps for the sides and backs right?
  • dearold_dad
    edited July 2014
    yea i have spent allot of money thinking i could drive them but i got the quality sound craze on i think ill get Pioneer SC-1323-K 7.2- and then see if i will still need an amp. this whole mess started when i found some rti8 for 100bucks lol .if im open to other brands of of same and beter quality that you have tried and tested word of mouth is always best.thanks
  • Sherardp
    Sherardp Posts: 8,038
    edited July 2014
    Pioneer SC 75 and you will not need the external power amp unless you want pure madness. The receiver is powerful enough and has plenty of bells & whistles to handle new stuff coming down the pipeline.
