wiring
jumper314
jumper314 Posts: 7
Hello everyone, I just purchased an Adcom GFA-555 power amplifier that I want to hook up to my Onkyo NR-717. If someone could tell me what would be the best way to wire it and what kind of wiring I need. I have Polk Audio RTiA9 speakers. I thank you for your time. Jumper314
Post edited by jumper314 on
    F1nut Posts: 51,776
    edited July 2014
    I'll assume your AVR has pre-outs. So, you use RCA cables to connect from the pre-outs to the amp.
  • jumper314
    jumper314 Posts: 7
    edited July 2014
    Thank you very much.
  • Glen B
    Glen B Posts: 269
    edited July 2014
    Make sure the amp is turned off before you connect/disconnect any cables.
