NPN Transistor Questions
F1nut
I need to replace some NPN transistors. The original is a 2SC870 spec'd at 30V, 0.03A, 0.2W, 150MHz.
These are suggested new replacements.
http://www.mouser.com/ProductDetail/Central-Semiconductor/2N3707/?qs=%2fha2pyFadugSm4f7j2P5eC7hn5ON5G8x7%252bJtYJRzyFU%3d
http://www.mouser.com/ProductDetail/Fairchild-Semiconductor/KSC1845FTA/?qs=%2fha2pyFadujuRv8Fbx51XeLs97y508AFaz7wFPeqKuw%3d
These are suggested NOS, but I'm a bit concerned about their age even though they NOS.
http://www.ebay.com/itm/2SC1682-Original-Toshiba-Transistor-2-pcs-/291177243389
Which one is the better match/choice???
Post edited by F1nut on
I would just stick with the new recommended replacements. The ones on eBay seem a little pricey. Here is the same part number from MAT electronics:http://www.matelectronics.com/electronic-repair-parts/semiconductors/2sc-semiconductor/semiconductor-2sc1682/
I don't remember their order minimum but they sell a lot of low cost odd items: http://matelectronics.com/content/catalog/mobile/index.html2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Sub 1 - Mirage Omni S8 | Sub 2 - Mirage Omni S8
Thanks for the link, but they are out of stock.
No one here knows what specs matter?Political Correctness'.........defined
President of Club Polk -
All the specs matter if you think about the fact that the best replacement is a new unit with the same model number. So, Breakdown Voltage, Max Current, Max Power, Max Frequency, Case type, and material are what you want to match to the reccomended replacements. I think these are general purpose amp units? So, theres no reason I can think ofwhy it should be more complex than that. What part of the circuit are these these located?2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Sub 1 - Mirage Omni S8 | Sub 2 - Mirage Omni S8
I agree and that makes sense to me, but it doesn't seem like one can find exact replacements for any transistor.I think these are general purpose amp units?
These are low power, low noise.What part of the circuit are these these located?
Pre amp board and headphone amp board.Political Correctness'.........defined
The gain is different with the two transistors
One is 200 and the other is 100
DC Collector/Base Gain hfe Min: 200
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Jesse, I wouldn't worry about the NOS part. Transistors don't age or breakdown sitting on a shelf. Electro-Migration isn't a problem, since they've never had current applied other than the initial testing done at the factory. Whatever the Silicon is encapsulated in may breakdown over time, but that's usually heat related. If they're a critical part, sometimes you have to bite the bullet and pay a premium for an original part.Home Theater/2 Channel:
dhsspeakerservice.com/ -
The TO-92 package has no standard pinout so you gotta check your replacements data sheet and stick the leads in the right hole. You can have E-B-C, E-C-B or B-E-C.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
disneyjoe7 wrote: »The gain is different with the two transistors
Ah, now that is one spec that I didn't pay attention to.
So, the 2SC870 has a forward current transfer ratio (hFE), min: 250, but doesn't state if that is the hFE1 or hFE2 spec.
The 2N7307 lists the hFE1 spec at minimum 100, maximum 400, but lists nothing for the hFE2 spec.
The KSC1845 lists the hFE1 at minimum 150, typical 580 and the hFE2 spec at 200 minmum, 600 typical.
Still confusing as hell.Political Correctness'.........defined
NTE makes equivalents for a lot of old transistors.
Here is an example:
http://www.weisd.com/test/GenericParts_WEISD_view.php?editid1=2SC870
I haven't had problems with NTE transistors (used about a dozen different replacements), but check the specs to be 100% sure.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
Here is an example:
Indeed they do, but everyone else has said their products are not good quality, so I ruled them out.Political Correctness'.........defined
NTE is just over priced IMO. Why would I pay $10 for their version of a component that everyone else sells for $1?2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Sub 1 - Mirage Omni S8 | Sub 2 - Mirage Omni S8
