Infinity Kappa Perfect 10.1 Subs
jim 249
jim 249 Posts: 347
edited June 2014 in Vintage Speakers
I am looking at buying a pair of these for my Carver ALIII's as these are highly recommended. They came in two configurations, a single 4 ohm voice coil and a dual 4 ohm voice coil. The pair I found is a dual 4 ohm voice coil. I need a 4 ohm voice coil to match the Carvers. Can the dual voice coil be hooked up to run as 4 ohms? Thanks for any help!
Post edited by jim 249 on
  • Mr. Bubbles
    Mr. Bubbles Posts: 736
    edited June 2014
    dual 4 ohm coils can be hooked up for either 2 or 8 ohms but not 4 ohms. However there is more to matching speakers to subs than just the impedance.
  • Habanero Monk
    Habanero Monk Posts: 715
    edited June 2014
    Can you simply purchase the 4ohm version and return the DV version?
  • villian
    villian Posts: 412
    edited June 2014
    If you run both woofers off one amp, independently of the mids/highs/xovers (Not sure how your speakers are setup) in the speaker cabinets, then you could run both at 4ohms off one amplifier. Just another possibility. ZLTFUL mentioned 4 channels of amplification and that's for both subs combined. So two channels for each sub. One set of +/- to each voice coil on each sub at 4ohms. Just to make sure you understood what he meant.
    Too many good quotes to list..waiting for some fresh ammo. :)
  • WLDock
    WLDock Posts: 3,073
    edited June 2014
  • jim 249
    jim 249 Posts: 347
    edited June 2014
    Thanks for the replies. Won't work. sigh
