SDA-1C Refurbish Plan
2
  • westmassguy
    westmassguy Posts: 6,850
    edited June 2014
    Jesse, I'll defer to you, but doesn't the paper backed veneer mitigate the perpendicular issue?
    Home Theater/2 Channel:
    dhsspeakerservice.com/
    F1nut Posts: 51,939
    edited June 2014
    It does make it less of an issue.
  • Sea
    Sea Posts: 317
    edited June 2014
    So is to suggest, the best option is to use fresh MDF under the veneer?
    Main-Carver TFM35(2),Carver C11 ,Carver SD/A 360 CD,Carver TX11 ,Grace Digital Tuner, Pioneer PL707 TT,Polk SDA1C
    Downstairs -Carver M1.5t, Carver C1 Pre, Carver TX10 Tuner, Carver TL3200 CD Player, Dual 1009 TT,Polk SDA SRS 2.3tl
    Study - Carver AV634 Amp, Carver CT7 Pre, Carver DTL50 CD Player, Polk RTA12c
  • westmassguy
    edited June 2014
    If they were mine, and they were in good shape, I'd re-veneer them.
    F1nut Posts: 51,939
    edited June 2014
    Sea wrote: »
    IMO yes, but the final choice is up to you. Perhaps, talk to some of the veneer suppliers for their opinion.
  • Conradicles
    Conradicles Posts: 6,372
    edited June 2014
    If you have a local auto paint shop you could go a different route like gloss black (Sorry but I love seeing pictures of my old speakers LOL)
  • Sea
    Sea Posts: 317
    edited June 2014
    Did you do this finish or did you have an auto body shop do it?
  • Conradicles
    edited June 2014
    A fellow Polkie who worked at an auto body shop.
  • Sea
    Sea Posts: 317
    edited June 2014
    I have the cabinets ready to paint. I plan to use a rattle can vinyl dye to refresh the sides, top and bottom even though they will be covered. The backs and face are in good condition. I have new fabric to cover new side panels. The old ones were warped badly. I bought the more expensive of the two fabric options that parts express offers. I think it is a good enough match that I do not plan to recover the grills, at least not right away.
  • Sea
    Sea Posts: 317
    edited June 2014
    I expect the new tweeters and drivers to arrive tomorrow. I think I have all the stuff I need except still waiting on BH5 to arrive and I still have not decided what to do with cx's yet. I think I will probably end up putting them back together with original cx's and listen for a while before proceeding. BTW, I have decided to do a little patch work on the tops and bottoms, stain black trying to preserve the grain and then finish with a satin lacquer.
  • nspindel
    nspindel Posts: 5,343
    edited June 2014
    Btw, I shipped you the BH5 today, Priority Mail. For the life of me I can't find the tracking slip. I'd expect it to arrive on Monday. The cuts aren't that neat, but they don't really need to be. If the tracking receipt pops up I'll PM you.
  • nspindel
    edited June 2014
    Btw, I had to fold the 4 strips in half to get them into the box. When you unfold them they will retain the impression of the fold for a while. If you let them sit overnight, the fold will be gone by the morning. The big sheet ships from Sonicraft folded in half.
  • Sea
    Sea Posts: 317
    edited June 2014
    Thank you.
  • Sea
    Sea Posts: 317
    edited June 2014
    On vacation this week. Wife is away so I have had a lot of time to work on the 1C's. I have done all except the crossovers. Late this afternoon I got one speaker back together and it sounds much much better than before. I should have the other completed tomorrow. I still have to install the hurricane nuts.
    Two things threw me a little.
    First, since I had the wiring diagrams from this site I did not pay close enough attention to the wires as I removed. On the stereo driver side the drivers are wired in series, the diagram says black to Positive for both and white to negative. This side of the harness has three black terminations and one white. Obviously the top driver had to have black to both posts. I was not sure which way to go.
    Secondly the new driver from polk did not have any polarity indication that I could find. I assumed positive was on the right as it is in the old stock drivers.
    Again, I am not certain that I have it wired correctly but it sounds good. I put this speaker in place of the left side of the 2.3TL's.
  • drumminman
    drumminman Posts: 3,396
    edited June 2014
    Easy way to check speaker polarity is to use a 1.5 volt battery (AA): http://www.techguys.ca/howto/speaker.html
    Note: speaker must be disconnected from amp (and probably Xover too).
  • Easy Runnin
    Easy Runnin Posts: 501
    edited June 2014
    One of my black wire has white tape on it to indicate negative, and my drivers have a red dot to indicate positive.
    HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
    Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
    2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
    Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
    BR - Yamaha CR800/Polk monitor 5
  • westmassguy
    edited July 2014
    Polarity should be stamped on the little piece that holds the spade/quick connects. It may be hard to see.
  • Sea
    Sea Posts: 317
    edited July 2014
    Thanks. I will look closer.
  • westmassguy
    edited July 2014
    If you look close, + is on the right, same position as the originals
  • Sea
    Sea Posts: 317
    edited July 2014
    Found it. Mine was actually scratched on the metal. Very hard to see.
  • Faustin
    Faustin Posts: 1,151
    edited July 2014
    I have gotten into the habit of using a red marker to mark the positive so it is easy for these older eyes to see.:)
  • Sea
    Sea Posts: 317
    edited July 2014
    Ok. Complete except for crossovers. Today, I evicted by RTi12's from my main listening room. I am impressed and amazed. I was driving the 12's bi amped with two Carver TFM35's which equated to 500 watts to each speaker. Since the 1C does not allow for bi-wiring I am only using one, 250 per side. The results are nothing short of phenomenal. I cannot imagine them being significantly better after rebuilding crossovers.
  • Conradicles
    edited July 2014
    Trust me, rebuilding the crossovers on any vintage Polks makes them better!
  • Sea
    Sea Posts: 317
    edited July 2014
    Oh, I believe it, I just cannot imagine it?
  • Faustin
    edited July 2014
    Sea wrote: »
    Listen for a time and then do it.You will not be disappointed.
  • Moose68Bash
    Moose68Bash Posts: 3,843
    edited July 2014
    Rebuild the crossovers with quality components.
    If you want somebody to do it for you, talk with Trey at Vr3 Mods.
    As Faustin says, "You will not be disappointed."
    Just my advice based on personal experience with two sets of vintage Polks, including one set of 1Cs.
  • nspindel
    edited July 2014
    Blackhole 5 arrived ok?
  • Sea
    Sea Posts: 317
    edited July 2014
    Yes. Great shape. Already installed. Thank you.
  • nspindel
    edited July 2014
    Nice. Glad to help.
  • Sea
    Sea Posts: 317
    Finally getting around to rebuilding crossovers today. Other than a very sample Advent rebuild this is my first. Wish me luck.
