Denon 3808 and Lsi
deepblue
deepblue Posts: 2
edited June 2014 in Electronics
I have Denon 3808 and am looking for the matching speakers. I found Polk Lsi15, 9 and center to be very good in both quality and discount. The only problem is that they run at 4 Ohm and there is the recommendation from Polk forum that 3808 cannot efficiently drive them. So, what's the solution?
- Still match these, but bi-amp them from unused surround to front.
- Find one 2 or 3 channel power amp with 200 watt per channel at 4 ohm, and let 3808 drive the other channels.
- Find 5 or 7 channel power amp with 200 watt per channnel at 4 ohm and use it alone.
I have done the research heavily but cannot find the one with the exact answer, and believe that this thread can help, please.;)
Post edited by deepblue on
  • McLoki
    McLoki Posts: 5,231
    edited January 2008
    You have answered your own question in reverse order of preference.....
    5 or 7 channel amp is the best solution.
    3 channel amp is lower cost and not quite as good a solution as above, but will probably work.
    If you do not want an external amp at all, don't get one (and bi-amp if possible) but you will still be limited to lower volumes, keeping your AVR VERY well ventilated (it will run pretty hot), and potentially running your AVR into protect mode (not cool half way through a demo) or blowing your speakers (not cool anytime).
    Good luck - The LSi's can be a pain to run properly, but are very much worth the effort.
    Michael
  • cfrizz
    cfrizz Posts: 13,415
    edited January 2008
    Find 5 or 7 channel power amp with 200 watt per channnel at 8 ohm and use it alone.
    Welcome to Club Polk DeepBlue.
  • deepblue
    deepblue Posts: 2
    edited January 2008
    Thanks all for the warm welcome. I'll bring my Denon for test with Lsi and find out how loud or stable it can run? Agree with you that the best permanent way is to have single power amp to take care all 5 channels eventhough it's hard to find the right choice here (in Thailand). BTW, the shop try to offer me the obsolete Subwoofer, PSW1200. Actually, for a pair of Lsi15 and 9, and one center, together with PSW1200, they offer me $2,800 which is quite good compared with other brands in the same range like NHT or Monitor Audio at almost double the price. What do you think?:rolleyes:
  • cathpah
    cathpah Posts: 8
    edited January 2008
    deepblue wrote: »
    Have you had a chance to test that speaker setup with the denon 3808? I'm thinking about purchasing this same receiver and speaker setup but I'm worried about the 4 ohm rating as well. Can you let me know how loud and stable you found that combo to be?
    thanks
    AVR: Denon 3808ci
    Mains: LSi15's
    Center:LSiC
    Surrounds: LSiFX's
    Rears: LSi9's
    Sub: AV123 MFW-15
    Display: Panasonic 58" 1080p plasma
  • cathpah
    cathpah Posts: 8
    edited October 2008
    cathpah wrote: »
    thanks
    I guess I'll answer my own question. I went ahead and ordered everything and crossed my fingers....turns out it works perfectly. I've gone very loud for long periods of time with no issues whatsoever.
    AVR: Denon 3808ci
    Mains: LSi15's
    Center:LSiC
    Surrounds: LSiFX's
    Rears: LSi9's
    Sub: AV123 MFW-15
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited October 2008
    You still should look into a nice 5 channnel amp. I will put a :D on your face.
  • cathpah
    cathpah Posts: 8
    edited October 2008
    leroyjr1 wrote: »
    I'm sure, but money is tight right now, and I'm running it as a 7.1 system so that would be pretty expensive.
    AVR: Denon 3808ci
    Mains: LSi15's
    Center:LSiC
    Surrounds: LSiFX's
    Rears: LSi9's
    Sub: AV123 MFW-15
  • mantis
    mantis Posts: 17,330
    edited October 2008
    deepblue wrote: »
    The Denon is not designed to handle a 4 ohm load. It's stable to 6 ohms. But it will drive the speakers just with barely no dynaic range. What happens is the amp has to use all of it's power to hold the heavier ohm load. Most receivers use smaller power supplies and caps. This is why most receivers don't do well driving lower ohm load speakers.
    Buying amp will be nessary if you want to use that receiver and speaker combo. I suggest checking out the rt line, they are pretty fantastic and will run without adding any amps on your Denon receiver.
    Good luck,
    Dan
    Dan
  • cathpah
    cathpah Posts: 8
    edited October 2008
    cfrizz wrote: »
    Is this really true? does the fact that that amp would have 200 watts per channel overcome the fact it's an 8ohm receiver? When I do buy an amp, I'll probably buy one used on audiogon, so a return policy isn't really an option there.
    would i really notice a huge difference from a more powerful amp that is still rated to only 8 ohms? sorry if this is a noobish question...I still (and always will) have loads to learn.
    AVR: Denon 3808ci
    Mains: LSi15's
    Center:LSiC
    Surrounds: LSiFX's
    Rears: LSi9's
    Sub: AV123 MFW-15
  • Face
    Face Posts: 14,340
    edited October 2008
    I would disregard the 200 watts at 8 ohms comment.
    What it boils down to is, you need a high current amp capable of driving those speakers correctly. There's plenty of good choices out there such as Rotel, Adcom, Sunfire, B&K, etc...
  • cathpah
    cathpah Posts: 8
    edited October 2008
    Face wrote: »
    sorry, when you say disregard it....do you mean it is false? Do i need to look specifically for an amp rated @ 4 ohms?
    with very little research, I was looking at the outlaw 7700.
    any solid/obvious recommendations for my best/cheapest option for this? I don't plan on doing much more upgrading for a while (had to convince the wife that these speakers would be all i'd need for the next 30 years...)
    AVR: Denon 3808ci
    Mains: LSi15's
    Center:LSiC
    Surrounds: LSiFX's
    Rears: LSi9's
    Sub: AV123 MFW-15
  • Face
    Face Posts: 14,340
    edited October 2008
    It's not false, just a little confusing as you should be looking for something with 4 ohm ratings.
    That outlaw will definitely get the job done.
  • tcrossma
    tcrossma Posts: 1,301
    edited October 2008
    I good quality high-current amp rated at 200w @ 8ohm will usually deliver somewhere between 300-350w @ 4ohm.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • cathpah
    cathpah Posts: 8
    edited October 2008
    Face wrote: »
    great...thanks very much. Sorry for any thread hijacking that I may have caused.
    That said, I should point out that I really haven't notice any faults in my setup thusfar....but I have no doubt that my system could sound even better with a dedicated amp. So, again, I want to say that the 3808 DOES work and I haven't had it go into safety mode a single time even while playing games/music/movies pretty damn loud. I just think that virtually every AVR could benefit from a dedicated amp, and thus that's why I've asked about amps.
    AVR: Denon 3808ci
    Mains: LSi15's
    Center:LSiC
    Surrounds: LSiFX's
    Rears: LSi9's
    Sub: AV123 MFW-15
  • MikeC78
    MikeC78 Posts: 2,315
    edited October 2008
    It will work as you are experiencing, however; you'll be taxing that AVR making it very hot and losing out on dynamics/SQ. An external amp such as the Outlaw you are looking it will relief you of any problems and bring a grin to your face.
  • cathpah
    cathpah Posts: 8
    edited October 2008
    MikeC78 wrote: »
    I believe you 100%, and wasn't saying that my setup is perfect at all.
    I was just trying to answer the OP's question (will this setup work) and indeed it will.
    now I personally, want to get an amp for the exact reason you stated...but that's different than what the OP asked. :)
    AVR: Denon 3808ci
    Mains: LSi15's
    Center:LSiC
    Surrounds: LSiFX's
    Rears: LSi9's
    Sub: AV123 MFW-15
  • MikeC78
    edited October 2008
    Disregard then, for some reason I thought you were the OP.
  • cfrizz
    edited October 2008
    Basically the more power the amp puts out at 8ohms the more power it will put out at 4. The more power you give to the LSI's the better they will perform! Hence the 200wpc recommendation.
    But it's your money & your speakers so do what you want.
  • cathpah
    cathpah Posts: 8
    edited October 2008
    cfrizz wrote: »
    ok...then I guess I am a bit confused. If my current avr can put out 140 wpc @ 8 ohms, then why do i need another amp? or am i mistaken on those stats?
    AVR: Denon 3808ci
    Mains: LSi15's
    Center:LSiC
    Surrounds: LSiFX's
    Rears: LSi9's
    Sub: AV123 MFW-15
  • cheddar
    cheddar Posts: 2,390
    edited October 2008
    What you want is an amp that has control and room to spare over the watts it delivers to your speakers. 1 lousy uncontrolled watt from an overtaxed amplifier section can kill an expensive lsi speaker no matter what the stated rating is. People are merely telling you that large and in charge is better than overtaxed and huffing to deliver the watts. The truth is that speakers rarely see 100 watts anyways. At very loud listening levels, you may be putting 10 watts into your speaker.
    Edit: Also, it's actually safer to exceed the power ratings of the speaker if you have controlled, clean power from a quality amp than it is to have that 1 lousy uncontrolled watt get through an underpowered receiver and smoke your speaks. Like I said, it's usually hard to go outside the power ratings of an lsi speaker anyways. But that's how important it is to have an amplifier that isn't being pushed to its limits...and of course they sound better too ;).
  • Ricardo
    Ricardo Posts: 10,636
    edited October 2008
    Receivers (with few exceptions) are not made to support 4 ohm speakers; they might have 140 or 200 WPC @ 8 ohms, but this does not mean they will be stable at 4 ohms.
    Most if not all separate amps will support 4 ohm, and sometimes 2 ohm speakers.
    SOPA
  • tcrossma
    edited October 2008
    cathpah wrote: »
    Because most receivers don't live up to their power ratings. And they generally do not have the power reserves and dynamics that a good amp will give you.
  • cfrizz
    edited October 2008
    Receiver makers lie like rugs when it comes to the power that thier receivers actually put out.
    You might get that 140 if you are just running 2 channels, but when you start running 5-7 channels you'll be lucky if you are getting 50-60wpc!
    Then toss in a couple of explosions & you could easily toast those beautiful, EXPENSIVE 4ohms LSI's!!!
    More than one person has come on here talking about a blown tweeter in thier brand new LSI's from playing them too loud on an insufficient receiver.
    We are simply telling you the expensive truth about owning the LSI series. We are trying to help you get the best for your money that will allow you to run your speakers to thier full potential.
    cathpah wrote: »
  • Logic 7
    Logic 7 Posts: 127
    edited October 2008
    cfrizz wrote: »
    This above statement is only true if the rating was taken at 1K. The Denon receiver in question was given its rating at 20-20,000hz.
  • WilliamM2
    WilliamM2 Posts: 4,806
    edited October 2008
    Logic 7 wrote: »
    Not true. They rate them with only two channels driven, they do have less power when all 7 channels are used. Have you ever seen the bench results of most recievers?
    BTW, what do you have to sell?
  • VXR8
    VXR8 Posts: 291
    edited October 2008
    I too have the 3808 plus the LSi9s as mains. I recently was utilising a Rotel RB-991 200 watts RMS x 2 into 8 ohm to drive the LSI9s. I am currently selling that amp to purchase either the Emotiva XPA-2 and XPA-5, or the MPS-2 amplifier. I have noticed since running the LSis through the receiver only, in 2 channel that the sound quality isn't as clean, the bass not so pronounced and tight and know I am not going to push the limits until I replace with any of the above amps. The Emotiva gear is great bang for buck ($799 each USD for XPA-2 and the XPA-5 and $1699 for the MPS-2). You don't realise how much an amp improves the sound until you take it away.
    Good luck with your endeavours.
    Regards - Gaz from the land of Oz
    Main System
    Denon - AVC-4700H
    Emotiva - XPA-9
    Cambridge Audio - Azur 851C - CXUHD
    Polk Audio - Legend L800 - Legend L400 - Legend L900 - LSiM fx - OWM3
    SVS - PB1000 x 2
    Foxtel - iQ4
    Belkin - Pure AV PF40
    Sony K77A9G
    Front Room System
    PS Audio - Sprout 100
    Cambridge Audio - CXC S2 - CA752BD
    Sony - UBX800 4K BluRay
    Polk Audio - Legend L200
  • Logic 7
    Logic 7 Posts: 127
    edited October 2008
    WilliamM2 wrote: »
    This not always the case
    WilliamM2 wrote: »
    Many times. This maybe true on a lot of receivers maybe but not all.
    WilliamM2 wrote: »
    Well I was recomended this site by someone. Maybe they were wrong. I dont have enough post to sell anything.
  • zx_toth
    zx_toth Posts: 417
    edited October 2008
    In my opinion it is not worth risking your expensive gear by improperly running them. Sure you can get away with a lot of things in life, like speeding in car, swiping a pen here and there from work but some of it might get you in trouble eventually and when that trouble is blowing a tweeter in your LSis or shortening the life expectancy of your Denon 3808 dont cry to the Manufacterurs of the speakers or recievers or on this forum when they cease to function properly or your warranty us not honored because of not properly setting up your equipment.
    Z
  • cfrizz
    edited October 2008
    bingo!!!!
    zx_toth wrote: »
    in my opinion it is not worth risking your expensive gear by improperly running them. Sure you can get away with a lot of things in life, like speeding in car, swiping a pen here and there from work but some of it might get you in trouble eventually and when that trouble is blowing a tweeter in your lsis or shortening the life expectancy of your denon 3808 dont cry to the manufacterurs of the speakers or recievers or on this forum when they cease to function properly or your warranty us not honored because of not properly setting up your equipment.
    Z
  • Unknown
    edited June 2014
