What to power my B&W with?
Webb_03
Webb_03 Posts: 42
edited June 2014 in 2 Channel Audio
Bought the CM 10's today, they are 30-300 watts @ 8 ohms. Now i have a Carver M4.0t that runs 375 rms, Obviously enough power and headroom. I'm In rebuilding mode though. Trying to possibly get away from Carver/Sunfire. I was looking into Rotel. Seemingly nothing in the 300wpc power range is ever for sale on ebay, other than big **** mono blocks. Should i find a 5 channel thx amp and bridge it for cheap bang for the buck? Is this gonna sound inferior to a good 300wpc amp? Any other brands anyone has heard on b&w speakers that sound good or better?
B&W CM10 Mains, Monitor 40 Surrounds, B&W Cm Centre, PSW 125 sub/ CV 10" sub, Marantz 7701 Processor, Carver M4.0T, Carver 705x 5 channel, 60'' Sharp LED, Xbox One, Xbox 360, Sonos, and of course my trusty laptop for hi res ( for now)
Post edited by Webb_03 on
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited June 2014
    Are you sticking with separates or willing to consider a good used integrated?
    And - most importantly - what is your budget so we can help spend every single penny! :cheesygrin:
  • deronb1
    deronb1 Posts: 5,021
    edited June 2014
    Congrats on the new speakers! I have never heard the CM10s but have heard various B&Ws powered with McIntosh, Cary, Parasound and Rotel. If I had to rank em, i guess i would go Cary, Mac, Parasound, Rotel
  • rpf65
    rpf65 Posts: 2,127
    edited June 2014
    I vote for something from NAD, M2 If in your price range.
    edited June 2014
    Webb_03 wrote: »
    Is this inquiry based on what your reading on the back of the speaker ? 30-300 watts ? You think you need a 300 watt amp ?
    Those manufacturer stated numbers mean little. Current....good high current amps is all you really need. Parasound, B&k, McCormack, Bat, Cary, Butler, just to name a few, would pair up nicely. Integrateds from Musical fidelity should too. The Rotel imho isn't a good match.
  • mantis
    mantis Posts: 17,554
    edited June 2014
    I suggest looking into NAD and Rotel. They are the 2 by far are the best bangs for bucks on the planet right now new.
    You got great speakers, don't cheap out on driving them.
    Dan
  • RamZet
    RamZet Posts: 792
    edited June 2014
    Im was driving my CM9s with a Rotel @ 135w per ch. Sounds great but its not enough. Any B&W owner will tell you that they are hard to drive.
    I bumped up to a Crestron AMP. I have the unit in bridge mode. I am sending 220w to the highs and 220w to the lows ( 440w to each speaker).
    They sound even better and I can tell they want more.
    But back to your question.
    I would get at least 150-200 watts into each of the CM10s. Anything lower and you would being yourself a disservice.
    Like others have stated, B&W pairs nice with Mcintosh, Krell, Rotel and Classe.
    Rotel and B&W are partners ( B&W Group is made up of B&W, Rotel and Classe).
    B&K amps sound great on B&Ws and so do Bryston amps.
    I would get something with at least 4ch so you can take advantage of all four post on the speakers.
    ( I am basing all of this on my 7 years of nearly exclusive B&W installs and experience with the amps above.)
    B&W CM9Classé Sigma
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited June 2014
    deronb1 wrote: »
    Think you hit the nail right on the head thier deronb1! +1 in that order.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • Erik Tracy
    edited June 2014
    I think we have a 'drive by'...
  • Webb_03
    Webb_03 Posts: 42
    edited June 2014
    I'm looking to spend 500-1000 on an amp. And I have always been of the opinion that it is better to have too much power than risking not enough. Lots of good input so far tho.
  • bobsauto49
    bobsauto49 Posts: 973
    edited June 2014
    Get a B&K 200.2, or a REF 2220, and NEVER look back! Wish I had mine back!!
    "Everything I ever did in my life worthwhile I caught hell for"
