adcom gfa-7607 wiring
evertune
I was wondering if any one knows if I could split the sub-woofer rca out from my Onkyo and use 2 of the Mono Block amps in the 7607 to double the wattage going to 1 sub. single voice coil?
Thoughts?
david.d
Thoughts?
david.d
Post edited by evertune on
Hello,
I'm afraid you can't connect two different amplifiers to the same voice coil, you would short both amplifiers.
Regards, Ken -
Thoughts?
david.d
my thoughts are that it is ideas like this that keep the repair techs in business....and the audio shops too...better re think what you are doing man...no offense intended....
