adcom gfa-7607 wiring
evertune
evertune Posts: 8
I was wondering if any one knows if I could split the sub-woofer rca out from my Onkyo and use 2 of the Mono Block amps in the 7607 to double the wattage going to 1 sub. single voice coil?
Thoughts?
david.d
Post edited by evertune on
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited June 2014
    Hello,
    I'm afraid you can't connect two different amplifiers to the same voice coil, you would short both amplifiers.
    Regards, Ken
  • Msabot1
    Msabot1 Posts: 2,098
    edited June 2014
    evertune wrote: »
    Thoughts?
    david.d
    my thoughts are that it is ideas like this that keep the repair techs in business....and the audio shops too...better re think what you are doing man...no offense intended....
