Need a new (and cheap) music player suggestions
muncybob
muncybob Posts: 3,238
edited June 2014 in The Clubhouse
My old Sansa mp3 player operated by a single AAA battery has bit the dust. Looking for a replacement that has decent sound but not looking to spend more than $50 or so. I mainly use the thing when cutting grass. You can find many on Amazon but I really don't know the difference between a clip, zip, etc.
Yep, my name really is Bob.
Post edited by muncybob on
    EndersShadow Posts: 17,703
    edited June 2014
    Honestly just look at ebay for a older ipod classic or one of the newer models. Can probably snag one of those for that.
  • muncybob
    edited June 2014
    Would one that plays more than just mp3 formats be the way to go? I doubt I would hear any difference cutting the grass but what if I plugged it into my car or a speaker dock? I'm guessing at my price point it probably doesn't matter much?
  • jwhitakr
    jwhitakr Posts: 568
    edited June 2014
    If you are plugged into the Apple "eco-system" (i.e. buy all your music from iTunes) I'd say get an older model iPod model. If you are not tied to Apple, just get a 4GB or 8GB Sansa Clip+ along with a microSD card for plenty of extra storage space. I've had my Clip+ for years (maybe 3-4 years?) and it still works great.
    My HT
    HDTV: Panasonic PT-61LCX65 61" Rear Proj. LCD
    AVR: Harman Kardon AVR 235
    Video: 80GB PS3, Toshiba HD-XA1 HD DVD
    Fronts: Polk Audio RTi8
    Center: Polk Audio CSi3
    Amp: Emotiva LPA-1
    Surrounds: Polk Audio R150
    Sub: HSU STF-3
    The only true barrier to knowledge is the assumption that you already have it. - C.H. Dodd
  • muncybob
    edited June 2014
    Yep, the Sansa Clip+ is what I decided on. My wife will be happy when it arrives so I can stop swiping her player.
