Need a new (and cheap) music player suggestions
muncybob
My old Sansa mp3 player operated by a single AAA battery has bit the dust. Looking for a replacement that has decent sound but not looking to spend more than $50 or so. I mainly use the thing when cutting grass. You can find many on Amazon but I really don't know the difference between a clip, zip, etc.
Yep, my name really is Bob.
Post edited by muncybob on
Honestly just look at ebay for a older ipod classic or one of the newer models. Can probably snag one of those for that."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
Would one that plays more than just mp3 formats be the way to go? I doubt I would hear any difference cutting the grass but what if I plugged it into my car or a speaker dock? I'm guessing at my price point it probably doesn't matter much?Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
If you are plugged into the Apple "eco-system" (i.e. buy all your music from iTunes) I'd say get an older model iPod model. If you are not tied to Apple, just get a 4GB or 8GB Sansa Clip+ along with a microSD card for plenty of extra storage space. I've had my Clip+ for years (maybe 3-4 years?) and it still works great.My HT
HDTV: Panasonic PT-61LCX65 61" Rear Proj. LCD
AVR: Harman Kardon AVR 235
Video: 80GB PS3, Toshiba HD-XA1 HD DVD
Fronts: Polk Audio RTi8
Center: Polk Audio CSi3
Amp: Emotiva LPA-1
Surrounds: Polk Audio R150
Sub: HSU STF-3
The only true barrier to knowledge is the assumption that you already have it. - C.H. Dodd -
Yep, the Sansa Clip+ is what I decided on. My wife will be happy when it arrives so I can stop swiping her player.Yep, my name really is Bob.
