Parasound HCA 1200 11
tophatjohnny
Maybe someone here knows?? Is this amp able to handle a 3/3.5 ohm load??
Post edited by tophatjohnny on
Ck the specs, the 1200 goes to 2 ohm easly. Not positive on the 1200ll.or call parasound tomorrow and tjey can answer that.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
soundfreak1 wrote: »Ck the specs, the 1200 goes to 2 ohm easly. Not positive on the 1200ll.or call parasound tomorrow and tjey can answer that.
Thanks Stan. that's what I was going to do, as I'm not sure what the differences between the 1200 and the 1200 II are, besides the II is a newer model??"if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
I believe its mainly power supply changes. And parts brand changes.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Talked to Tony @ Parasound and yes the amp will handle the 3-3.5 ohm load but suggested not to go any lower. Thanks"if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
