Parasound HCA 1200 11
tophatjohnny
tophatjohnny Posts: 4,186
edited June 2014 in Electronics
Maybe someone here knows?? Is this amp able to handle a 3/3.5 ohm load??
Post edited by tophatjohnny on
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited June 2014
    Ck the specs, the 1200 goes to 2 ohm easly. Not positive on the 1200ll.or call parasound tomorrow and tjey can answer that.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • tophatjohnny
    edited June 2014
    Thanks Stan. that's what I was going to do, as I'm not sure what the differences between the 1200 and the 1200 II are, besides the II is a newer model??
  • soundfreak1
    edited June 2014
    I believe its mainly power supply changes. And parts brand changes.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • tophatjohnny
    edited June 2014
    Talked to Tony @ Parasound and yes the amp will handle the 3-3.5 ohm load but suggested not to go any lower. Thanks
