Klipsch klf10s for a hunny
scottyboy76
scottyboy76 Posts: 2,905
edited June 2014 in For Sale (FS) Classifieds
The cabs are scratched up from being laid sideways on stone shelving used in a two channel tv setup.
there is a rattle in one speak, I have removed the horns looking for something loose, as it is only when cranked prety good, not like a floppy driver.
I will remove and inspect for anything obvious behind the woofs tonight.
These are very obviously party speaks, the bass is pretty impressive at this price, and the horns, for the short time i listened, did not seem irritating.
Will meet within 1 hour drive of Ga Tenn N.C. border
humpty dumpty was pushed
Post edited by scottyboy76 on
  • boston1450
    boston1450 Posts: 7,758
    edited May 2014
    Hundred bucks those would be gone up here
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • DaveHo
    DaveHo Posts: 3,583
    edited May 2014
    Check to see if the back panel is loose. Cabinet glue failures are a common problem on the KLF series.
    Oh, & that's a heck of a good price BTW.
  • scottyboy76
    edited May 2014
    That was the first thing i checked,it sounds like it is higher up, i will be taking out the woofs tonight and see if a piece of wood has come loose, Its not like its a really bad noise, and to watch tv its fine, only rattles when you crank it up pretty good.
  • scottyboy76
    edited May 2014
    Just hooked them up again in the living room system.
    They actually sound really good playing paul simons graceland, about as loud as anyone could listen comfortably.
    You have to turn the volume up to levels that would not be comfortable to listen to, to make the buzzing sound.
    I found where it appears.
    If you push the wooden back pice in, right about between the height of the horn tweet and the first woofer,the vibration stops, I will be removing the top woofer to see if there is some wood separating those two chambers, but i doubt it.
    Also gave them a wipe to dust, and used a black marker to touch up the scratches, they dont look awful for a few seconds of touchup and sound damn good for a hundred bucks
  • scottyboy76
    edited May 2014
    I am now listening to Houses of the holy cd, rain song.
    I walked over to the front door to check out believe it or not, that it just began to rain, I guess its about ten feet.
    The bass changed considerably, these would be great in a large room, or garage, and the vibration problem is non existant at this volume, as loud as i would want to listen.
    But it is there at very high volumes, just want to disclose.
  • xjghost
    xjghost Posts: 1,115
    edited May 2014
    Man I bet those would be great in my garage...... Unfortunately I cannot get them right now. GLWS!
    HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
    Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
    Additional projects: RTA 12c's
  • HTguru1982
    HTguru1982 Posts: 1,066
    edited May 2014
    They look like they weigh a ton. My back is hurting just looking at them. GLWTS!
    Display: Sony 42" LCD
    Sources: Harman Kardon DVD-27,
    Panasonic DMP-BDT110 blu ray player
    AVR: Sony STR-DA2400ES
    Amps: Sonance Sonamp 260(fronts),
    Kenwood KM-894(surrounds)
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
    Surrounds: NHT Super One
    Subwoofer: SVS PB10-ISD
  • scottyboy76
    edited June 2014
    price reduction before going to battered womens and children shelter thrift store
    75 BUCKS
    , trust me, you have to crank the s&*t out of them to get the vibration, have not checked to see if its a matter of **** some bracing or whatever, just wanted to be totally honest
  • scottyboy76
    edited June 2014
    Okay, 50 bucks, or monday they go to the shelter thrift store.
  • erniejade
    erniejade Posts: 6,321
    edited June 2014
    wish you were closer. I would take them
  • erniejade
    edited June 2014
    PM sent. I have a friend in KY that needs speakers. This would work for him nicely actually.
