Totally tubular...
[Deleted User]
Hello,
Unusual request, does anyone know where I could find a small piece of metal tube (any kind of metal will work) that has an outside diameter of 0.175" and an inside diameter of 0.130"?
Thanks, Ken
Thanks, Ken
HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
Try a hobby shop. The ones that do airplanes have all sorts of stuff like that.
While you're there, try NOT to buy a helicopter kit."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
Ken, try Amazon for Stainless Steel hypodermic tubing. Should be close to your requirements.
Like this maybe....
http://www.amazon.com/Stainless-Steel-Hypodermic-Tubing-Length/dp/B001DCZLTY/ref=sr_1_1/175-4666200-0728206?s=industrial&ie=UTF8&qid=1401851793&sr=1-1Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Thanks for everyone's suggestions, I think I found what I need at Amazon from SCompRacer's link. I'm replacing the output volume control with a nice new one with concentric right and left channels. Kind of hard to find, but I had one made for me. The new unit's inner shaft was too small for the set screw on the control knob to tighten down. The tube will act as a sleeve and thicken the shaft enough for the screw to work.
This deck has been a real challenge, finding the right edge card connectors for the circuit boards, etc.
Again, thanks! -
Maybe knitting needles.
Boye Single Point Aluminum Knitting Needles
Lots of sizes at Walmart. -
Knitting needles is a really clever suggestion, plus they taper along their length. I'll remember that in the future if I need something similar.
SCompRacer wrote: »Stainless Steel hypodermic tubing. [/url]
You shootin' up again Rich?:twisted:Carl -
