Totally tubular...
[Deleted User]
[Deleted User] Posts: 7,658
edited June 2014 in The Clubhouse
Hello,
Unusual request, does anyone know where I could find a small piece of metal tube (any kind of metal will work) that has an outside diameter of 0.175" and an inside diameter of 0.130"?
Thanks, Ken
  • Irrenhaus
    Irrenhaus Posts: 1,092
    edited June 2014
    Check this website out they have a good selection.
    http://www.mcmaster.com/#metal-pipe/=s96zll
    HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
  • sucks2beme
    sucks2beme Posts: 5,606
    edited June 2014
    Try a hobby shop. The ones that do airplanes have all sorts of stuff like that.
    While you're there, try NOT to buy a helicopter kit.
    SCompRacer Posts: 8,513
    edited June 2014
    Ken, try Amazon for Stainless Steel hypodermic tubing. Should be close to your requirements.
    Like this maybe....
    http://www.amazon.com/Stainless-Steel-Hypodermic-Tubing-Length/dp/B001DCZLTY/ref=sr_1_1/175-4666200-0728206?s=industrial&ie=UTF8&qid=1401851793&sr=1-1
  • [Deleted User]
    edited June 2014
    Thanks for everyone's suggestions, I think I found what I need at Amazon from SCompRacer's link. I'm replacing the output volume control with a nice new one with concentric right and left channels. Kind of hard to find, but I had one made for me. The new unit's inner shaft was too small for the set screw on the control knob to tighten down. The tube will act as a sleeve and thicken the shaft enough for the screw to work.
    This deck has been a real challenge, finding the right edge card connectors for the circuit boards, etc.
    Again, thanks!
  • Speedskater
    Speedskater Posts: 495
    edited June 2014
    Maybe knitting needles.
    Boye Single Point Aluminum Knitting Needles
    Lots of sizes at Walmart.
  • [Deleted User]
    edited June 2014
    Knitting needles is a really clever suggestion, plus they taper along their length. I'll remember that in the future if I need something similar.
  • schwarcw
    schwarcw Posts: 7,341
    edited June 2014
    SCompRacer wrote: »
    Stainless Steel hypodermic tubing. [/url]
    You shootin' up again Rich?:twisted:
    Carl
    edited June 2014
    schwarcw wrote: »
    R u needling me?:cheesygrin:
