Polk 5 Jr's
gdphoto
gdphoto Posts: 182
edited June 2014 in Speakers
Hi, I have a pair of Polk 5 jr's. One sounds fine the other sounds higher and lower in volume. I'm guessing the cross over is bad. If I find a replacement XO, is it worth rebuilding?
Thanks! Gary
Hafler DH220 Power amp Recapped
Hafler DH110 Preamp Recapped
Hafler Digital FM Tuner
Virtue Audio M1 Piano CD Player
Technics SL-1210-MK5 with an Ortofon Black LVB250 Cartridge
Polk SDA1c's(Rebuilt XO's by Ben) RDO194 Tweeters
Post edited by gdphoto on
    pitdogg2 Posts: 27,317
    edited June 2014
    just rebuild the XO's in there. after 20+ years the caps have dried out.
  • gdphoto
    gdphoto Posts: 182
    edited June 2014
    How do I know which parts I nee to get.
  • Oldfatdogs
    Oldfatdogs Posts: 1,874
    edited June 2014
    In the vintage speaker section there's a sticky,all non SDA models.
    http://www.polkaudio.com/forums/showthread.php?38755-POLK-AUDIO-Speaker-Wiring-Schematics-amp-More-ALL-MODELS-except-SDA
    Find the model you have,then compare when you open them up.
    Hope this helps
    Dan
  • Nightfall
    Nightfall Posts: 10,083
    edited June 2014
    Bad caps can cause fluctuating volume?
    afterburnt wrote: »
    Village Idiot of Club Polk
  • drumminman
    drumminman Posts: 3,396
    edited June 2014
    It could also be poor connection from the binding post to the Xover, or from the Xover to the speakers. You'll need to open them up and have a look. As Old Fat Dogs mentioned, the caps are due for replacement. While you're at it I'd replace the resistors too.
    Modern film caps and non-inductive resistors will make those 5Jr's sound better than they did when they were new.
  • gdphoto
    gdphoto Posts: 182
    edited June 2014
    Thanks for all of your input!
