Suggestions for new bookie speakers for my son's birthday.
ROHfan
ROHfan Posts: 1,014
edited June 2014 in Speakers
Right now Jr. is using RTiA1s and he's pretty happy with them but he needs something more accurate as he's using them to monitor the mix in his small recording studio. He likes the RTiA's but since it's rear ported the sound tends to get mixed up behind his three tiled monitors and gets all boxy sounding.
I was thinking something along the lines of Totem Rainmakers or similar. Would like the budget to be around $300. Have heard some good things about Energy bookies as well as Wharfedale Diamonds 10.1. Any suggestions? I'm open to used if anyone here is selling something that fits in with what I'm looking for. Local sale on Long Island sweetens the deal.
TV: 65" Samsung QLED 4K
AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
Post edited by ROHfan on
  • Nightfall
    Nightfall Posts: 10,084
    edited May 2014
    FWIW I owned those Wharfedale's and I remember liking them.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • ROHfan
    ROHfan Posts: 1,014
    edited May 2014
    Nightfall wrote: »
    We were toying with the idea of adding an inexpensive tube amp to the mix and take out the tripath amps he's currently using. The sound could open up with that kind of upgrade.
  • voltz
    voltz Posts: 5,384
    edited May 2014
    I have some PSB's and I love there sound.
    check out these Alpha B1's on Audio advisor and read there reviews.
    http://www.audioadvisor.com/PSB-Alpha-B1-Bookshelf-Speakers/productinfo/PBALB1/#.U4qiGCgd2Ys
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited June 2014
    Pioneer Bookies. BS-SR22-LR or whatever their nomenclature is.
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
    edited June 2014
    Get some Yamaha NS10 Monitors if you want to mix. They're just about in every studio as a standard Bookshelf reference. Not the best sounding but FLAT! Very FLAT!
    cnh
  • Irrenhaus
    Irrenhaus Posts: 1,103
    edited June 2014
    Usher V-601 have pair love them. Front ported.
    http://www.usheraudio.com/Loudspeaker_V-601.html
    Cheers
    HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
  • deronb1
    deronb1 Posts: 5,021
    edited June 2014
    Older B&W DM series? I sold a pair to young fellow who wanted them specifically for mixing. Sealed.
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited June 2014
    You're not getting a pair of rainmakers for $300, and while they sound great they're probably not the best for mixing. They're a very musical speaker, but not the most accurate.
  • PSOVLSK
    PSOVLSK Posts: 5,390
    edited June 2014
    Polk LSi 7?
  • AsSiMiLaTeD
    edited June 2014
    not accurate enough for a studio monitor, they sound good but not ideal for recording or mixing
  • rooftop59
    rooftop59 Posts: 8,121
    edited June 2014
    Thy're big and ugly, but I use m5s with peerless in a nearfield office rig and while not entirely neutral (I mean seriously, what speaker is), they don't have any major frequency peaks or dips. The bass extension is excellent, and the passive radiator means that you can place them close to a wall. There are a bit warm sounding, so you would need to keep that in mind, but overall a pretty accurate speaker for a budget price.
    My other suggestion would be NHT SB2 or SB3. Acoustic suspension with solid bass extension (especially the 3), pretty darn revealing and accurate for the price. In fact one major complaint about that series is that they make bad recordings sound really bad, nothing there to sugercoat the ****. The one problem is that they need power; I tried running the SB1s with a sub on a t-amp, no go, sounded horrible, You'll want a good 100 watts of ss power. Another good thing is while there are not forward sounding like the super series was, they are not really laid back either, which makes them good for mixing.
    Game Room 5.1.4:
    Bedroom 2.1
  • Lan077
    Lan077 Posts: 31
    edited June 2014
    PSB Image B6's are being discounted on AA. A great all around full size bookie. PSB's build quality always impresses me, even their entry stuff. PSBs rarely go on sale, maybe a new model coming soon? I don't know if you can do much better for $300.
    http://www.audioadvisor.com/PSB-Image-B6-Bookshelf-Speakers/productinfo/PBIMB6/#.U5AElPldVYA
    F1nut Posts: 51,803
    edited June 2014
    rooftop59 wrote: »
    The SB3 is a good suggestion, which becomes an even better speaker with crossover upgrades, tames that metal dome quite nicely and lifts a veil. I also added Hurricane nuts to the woofers. Amazing bass from such a small speaker. I've driven them with a 75wpc tube amp and currently a 70wpc SS integrated. Great results with both.
