Polk SDA SRS 2 discussion.
Tucker_Z
Tucker_Z Posts: 21
edited June 2014 in Vintage Speakers
I recently bought a pair of SDA SRS 2 towers in MINT condition for $650 and was wondering what people's opinions are on the SDA SRS 2. Ive read that the SDAs are just something you have to experience. And so I got some. My other question is whether or not my amp will be able to power it-factoring in the impedance drops. I have a QSC GX7-should this do the job perfectly with some headroom?
AVRs
Marantz SR-7400 - My room
Speakers
Polk RTA15TL - My room
Polk Monitor 5 - My room
Post edited by Tucker_Z on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited May 2014
    The SRS 2 is a great speaker. You should be good to go with the QSC amp. Enjoy!
    F1nut Posts: 51,900
    edited May 2014
    Maybe some Peavy's would be a better match with that pro amp.
  • Schurkey
    Schurkey Posts: 2,122
    edited May 2014
    WHICH SRS 2? There are two versions. Early version is in essence a larger SDA 1B. Later version is a larger SDA 1C. The easy way to tell the difference is to look at the interconnect cable--is it blade/blade (early) or pin-blade (late)?
    Folks hardly ever specify which version they have unless pressed. Especially when advertising them for sale.
    Either way, they're terrific speakers; but the pin/blade later units are easier to drive. The blade/blade version MUST have a common-ground amplifier, the pin/blade can use an AI-1 or aftermarket equivalent, and therefore the common-ground requirement doesn't apply.
    A search will reveal considerable info on modifying the early version.
  • PolkieMan
    PolkieMan Posts: 2,446
    edited May 2014
    Be sure and download the SDA Handbook to find out more about what you have.
    http://vr3mods.com/uploads/SDA_Handbook_2011_Rev2.pdf
  • helipilotdoug
    helipilotdoug Posts: 1,230
    edited June 2014
    I have the blade/blade version of the SRS 2 speakers that have been modified and tweaked to the max and are wonderful. With the Sunfire amp I have them hooked up to, they are a perfect match. They are well worth doing the rebuild and mods.
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • deafbykhorns
    deafbykhorns Posts: 150
    edited June 2014
    I agree, a class d or class h amp should be used to drive a sub only.....
    It would be much smoother with a class A A/B amp
    Main System- Scratch built 2A3 , Lightspeed preamp, Technics SP15/Graham/XV1s,Klipschorns w/ALK xovers/Trachorns, Speakercraft MT8(4), Sonos ZP90, Yamaha Aventage for surround
    Office System- Adcom GTP500, Bedini 45/45,Lexicon RT-20,Enlightened Audio DAC, Polk SDA2.3TL, Northcreek Borealis
  • chandler9a
    chandler9a Posts: 878
    edited June 2014
    I have a pair of the blade/blade SRS 2s and love them. I have not modded them (other than the tweeters) but hope to some day.
  • mlong
    mlong Posts: 134
    edited June 2014
    Thanks Schurkey for the info and PolkieMan for the link. I now know exactly what I have - pin/blade.
    [HOME THEATRE]
    Samsung LED HDTV - Pioneer VSX-1014TX (AVR) - Parasound HCA-1200 II - Philips DVP642 (DVD)
    Polk Monitor 10B (Side Surround) - Bang & Olufsen P45 (Rear Surround) - Polk CSi30 (Center Channel)
    SVS PB12-ISD/2 (Sub)
  • GlennDog
    GlennDog Posts: 3,152
    edited June 2014
    mlong wrote: »
    Me, too. Nicely moded and very pleased, you should consider the upgrades. You wont regret it . . .
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • Dawgfish
    Dawgfish Posts: 2,554
    edited June 2014
    I have a set of pin/blade SRS 2s also. Love 'em!
