Polk SDA SRS 2 discussion.
Tucker_Z
I recently bought a pair of SDA SRS 2 towers in MINT condition for $650 and was wondering what people's opinions are on the SDA SRS 2. Ive read that the SDAs are just something you have to experience. And so I got some. My other question is whether or not my amp will be able to power it-factoring in the impedance drops. I have a QSC GX7-should this do the job perfectly with some headroom?
AVRs
Marantz SR-7400 - My room
Speakers
Polk RTA15TL - My room
Polk Monitor 5 - My room
Speakers
The SRS 2 is a great speaker. You should be good to go with the QSC amp. Enjoy!HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Maybe some Peavy's would be a better match with that pro amp.
WHICH SRS 2? There are two versions. Early version is in essence a larger SDA 1B. Later version is a larger SDA 1C. The easy way to tell the difference is to look at the interconnect cable--is it blade/blade (early) or pin-blade (late)?
Folks hardly ever specify which version they have unless pressed. Especially when advertising them for sale.
Either way, they're terrific speakers; but the pin/blade later units are easier to drive. The blade/blade version MUST have a common-ground amplifier, the pin/blade can use an AI-1 or aftermarket equivalent, and therefore the common-ground requirement doesn't apply.
A search will reveal considerable info on modifying the early version. -
Be sure and download the SDA Handbook to find out more about what you have.
http://vr3mods.com/uploads/SDA_Handbook_2011_Rev2.pdfPOLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
I have the blade/blade version of the SRS 2 speakers that have been modified and tweaked to the max and are wonderful. With the Sunfire amp I have them hooked up to, they are a perfect match. They are well worth doing the rebuild and mods.Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com -
I agree, a class d or class h amp should be used to drive a sub only.....
It would be much smoother with a class A A/B ampMain System- Scratch built 2A3 , Lightspeed preamp, Technics SP15/Graham/XV1s,Klipschorns w/ALK xovers/Trachorns, Speakercraft MT8(4), Sonos ZP90, Yamaha Aventage for surround
Office System- Adcom GTP500, Bedini 45/45,Lexicon RT-20,Enlightened Audio DAC, Polk SDA2.3TL, Northcreek Borealis -
I have a pair of the blade/blade SRS 2s and love them. I have not modded them (other than the tweeters) but hope to some day.
Thanks Schurkey for the info and PolkieMan for the link. I now know exactly what I have - pin/blade.[HOME THEATRE]
Samsung LED HDTV - Pioneer VSX-1014TX (AVR) - Parasound HCA-1200 II - Philips DVP642 (DVD)
Polk Monitor 10B (Side Surround) - Bang & Olufsen P45 (Rear Surround) - Polk CSi30 (Center Channel)
SVS PB12-ISD/2 (Sub) -
Me, too. Nicely moded and very pleased, you should consider the upgrades. You wont regret it . . .AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
I have a set of pin/blade SRS 2s also. Love 'em!
