My first Amp
gce
gce Posts: 2,158
edited May 2014 in Electronics
I have a Marantz 7008 and I'm thinking about getting a 2 channel amp for when I'm using the Marantz for 2 channel listening. I use my system for TV, Movies, LP's, DVD's SACD's and streaming FLAC. I use the 7008 for everything so it could be on maybe 6-8 hours a day on the weekends. So my question is if I have an external amp that has to be on this amount of time will this hurt anything? Are external amp's designed to be on this long? I know they get hot. I Think I'm going with the Parasound A21 or A31.
Anaheim Hills CA,
Post edited by gce on
  • chumlie
    chumlie Posts: 8,658
    edited May 2014
    My Parasound has been on over a year and a half with no problems. With a load on it 14 to 16 hrs during the weekend.
  • hochpt21
    hochpt21 Posts: 5,423
    edited May 2014
    I leave my B&K amp on all the time unless there's a storm.
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited May 2014
    My Parasound is usually on for at least 10 hours a day, many days it is up to 18 as I am an insomniac.
  • deafbykhorns
    deafbykhorns Posts: 150
    edited May 2014
    It will be fine but keep in mind heat drys out capacitors so get the amp checked about every 10 yrs.
    A well designed amp will have some spacing between driver transistors and caps. Those that don't will fail quicker.
    I would presume a Parasound amp would be well designed and reliable. With some multichannel amps, the designer doesn't have the space to keep these clearances.
    Main System- Scratch built 2A3 , Lightspeed preamp, Technics SP15/Graham/XV1s,Klipschorns w/ALK xovers/Trachorns, Speakercraft MT8(4), Sonos ZP90, Yamaha Aventage for surround
    Office System- Adcom GTP500, Bedini 45/45,Lexicon RT-20,Enlightened Audio DAC, Polk SDA2.3TL, Northcreek Borealis
  • gce
    gce Posts: 2,158
    edited May 2014
    Thanks guys, very reassuring. Any dealer suggestions?
    Anaheim Hills CA,
  • ratster
    ratster Posts: 324
    edited May 2014
    Great service from audio advisor if buying a new parasound. If you want quality used gear, check the fm section.
    Main
    Parasound P5
    Parasound A21
    CA music streamer
    marantz 6005
    Clear Day dbl.shotgun
    Morrow Xlr
    1.7 Maggies
    Bedroom
    adcom Gfp750
    Adcom 555
    Rotel 1072
    CA tuner
    LsiM703
    Clear day dbl shotgun
  • gce
    gce Posts: 2,158
    edited May 2014
    Now I'm reading about unbalanced and balanced connections. I can only use RCA unbalanced connection to my Marantz. The say you can get some hum or buzz with an unbalanced connection. How common is this and is there a way to fix it if it happens?
    I'd hate to get something like this and not be able to live with a hum or buzz because I don't have a pre-amp!
    Anaheim Hills CA,
  • chumlie
    edited May 2014
    You should be fine with the RCA's. Never heard of buzz coming from using RCA's myself. Get a decent set of IC's and your golden.
  • Geoff4rfc
    Geoff4rfc Posts: 2,816
    edited May 2014
    I have an AVR, three amps, two mono blocks and a three channel amp, all RCA cables; Emotiva and Monoprice cables, narry a hum.
    There are many from Monoprice, this I've found to be "decent"
    http://www.monoprice.com/Product?c_id=102&cp_id=10236&cs_id=1023603&p_id=2681&seq=1&format=2
    I use two six foot cables for my mono blocks and a 25'er for one of my subs, I have no complaints and no problems, and the price........priceless :)
    Source: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
    Cables: AudioQuest McKenzie XLR's/CDP/Amp, Carbon 48/BRP, Forest 48/Display, 2 channel speaker cable: Furutech FS Alpha 36 12AWG PCOCC Single Crystal (Douglas Connection)
