My first Amp
gce
I have a Marantz 7008 and I'm thinking about getting a 2 channel amp for when I'm using the Marantz for 2 channel listening. I use my system for TV, Movies, LP's, DVD's SACD's and streaming FLAC. I use the 7008 for everything so it could be on maybe 6-8 hours a day on the weekends. So my question is if I have an external amp that has to be on this amount of time will this hurt anything? Are external amp's designed to be on this long? I know they get hot. I Think I'm going with the Parasound A21 or A31.
Anaheim Hills CA,
Post edited by gce on
My Parasound has been on over a year and a half with no problems. With a load on it 14 to 16 hrs during the weekend.
I leave my B&K amp on all the time unless there's a storm.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A
My Parasound is usually on for at least 10 hours a day, many days it is up to 18 as I am an insomniac.
It will be fine but keep in mind heat drys out capacitors so get the amp checked about every 10 yrs.
A well designed amp will have some spacing between driver transistors and caps. Those that don't will fail quicker.
I would presume a Parasound amp would be well designed and reliable. With some multichannel amps, the designer doesn't have the space to keep these clearances.Main System- Scratch built 2A3 , Lightspeed preamp, Technics SP15/Graham/XV1s,Klipschorns w/ALK xovers/Trachorns, Speakercraft MT8(4), Sonos ZP90, Yamaha Aventage for surround
Office System- Adcom GTP500, Bedini 45/45,Lexicon RT-20,Enlightened Audio DAC, Polk SDA2.3TL, Northcreek Borealis -
Thanks guys, very reassuring. Any dealer suggestions?Anaheim Hills CA,
2 Channel: Rogue RP-5 / WireWorld Electra power cord / Marantz TT-15S1/ Ortofon - Quintet Black MC / Marantz NA8005 DAC / W4S mAmp's / Synology DS 216+ll-4TB / Polkaudio LSiM703 -
Great service from audio advisor if buying a new parasound. If you want quality used gear, check the fm section.Main
Parasound P5
Parasound A21
CA music streamer
marantz 6005
Clear Day dbl.shotgun
Morrow Xlr
1.7 Maggies
Bedroom
adcom Gfp750
Adcom 555
Rotel 1072
CA tuner
LsiM703
Clear day dbl shotgun -
Now I'm reading about unbalanced and balanced connections. I can only use RCA unbalanced connection to my Marantz. The say you can get some hum or buzz with an unbalanced connection. How common is this and is there a way to fix it if it happens?
I'd hate to get something like this and not be able to live with a hum or buzz because I don't have a pre-amp!Anaheim Hills CA,
You should be fine with the RCA's. Never heard of buzz coming from using RCA's myself. Get a decent set of IC's and your golden.
I have an AVR, three amps, two mono blocks and a three channel amp, all RCA cables; Emotiva and Monoprice cables, narry a hum.
There are many from Monoprice, this I've found to be "decent"
http://www.monoprice.com/Product?c_id=102&cp_id=10236&cs_id=1023603&p_id=2681&seq=1&format=2
I use two six foot cables for my mono blocks and a 25'er for one of my subs, I have no complaints and no problems, and the price........priceless
Set up: 11.2 HT + 2ch
Cables: Mogami AES from CDP to DAC - AQ McKenzie XLR from DAC to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 707 power conditioner.
