Suggestions for Replacing Wire
Faustin
I am planning to upgrade the binding posts on several of my speakers and I want to replace the wires from the binding posts to the crossover board. I am looking for suggestions in regards to brand, gauge etc.
Post edited by Faustin on
Since it's such a short distanced why not splurge a little. One choice is Ohno continuous cast copper with Teflon insulation. You can possibly find it on ebay, or buy some here: http://www.vhaudio.com/wire.html . I've done business with VH Audio for years and can verify that they're a stand up company."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
Thanks drumminman.
