which blade again?
leftwinger57
leftwinger57 Posts: 2,917
edited May 2014 in Vintage Speakers
I'm a little confused here. In the Handbook page marked for SDA 2B schematic OC dated 3/30/87 titled P01232002. In the bottom left corner there is a footnote saying the wire from the x-over should always be connected to pin #2 (the small pin) They are using the term pin but clearly it shows a blade designation as opposed to another schematic that does show pins. Through the years here I think ALL you guys say hook up that wire to the large blade. So what gives and which way is correct?
    F1nut Posts: 51,997
    edited May 2014
    That one and only that one has the blue wire connected to the small blade or pin as it is labeled on the schematic.
  • leftwinger57
    edited May 2014
    OK, so Jesse I think you know my 2Bs and were originally connected via large blade. Why and just for curiosity is it different on that schematic. Is it a generation type thing and if a newbie got a set of 2Bs that happened to have that wire disconnected how would they know which blade to put it on with exception of the size of the stakon crimps. The not marking of every model I always thought was nutty like calling SDA 2 but until you told me I had '87 2Bs I was clueless. I also said this many times that their way of even just naming their speakers was very confusing, simple mind yeah but they could have named them something other than numbers w/ decimal points in some cases if you know what I mean. I kinda know what model is which now but if my life depended on it I would have dead a long time ago.
    F1nut Posts: 51,997
    edited May 2014
    It was a transitional model.
    That's where schematics come in handy.
  • leftwinger57
    edited May 2014
    I didn't see your reply. Thanks, it makes all the sense now. My simple mind anology would be like the 1964 and a 1/2 Mustang. I wiil always have a problem w/ their nomenclature but that's just me.
