Digital cable recomendations
Sumerian
Ok first of all I am a strong believer of cables make a difference, so please don't derail this thread in to another cable wrestling.
Just to give a perspective , currently my rig is connected through MIT Shotgun S3 RCA's, XLR's and Speakers cables.
Except my surrounds (Douglas Cables).
I would appreciate if you guys can give me some recommendations for Ethernet Cable and USB Cables.
Post edited by Sumerian on
USB Cables.
Would recommend the Audioquest line of USB's, there is one made for every budget. Main thing is they are well made and built to last.2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
txcoastal1 wrote: »Would recommend the Audioquest line of USB's, there is one made for every budget. Main thing is they are well made and built to last.
Thanks for the reply.
Carbon seems to be right mix -
For an Ethernet cable, I highly recommend this one: http://www.acoustic-revive.com/english/pcaudio/lan_cable.html
The PCOCC used in it solid core and it's the best sounding Ethernet cable I have heard. I have NOT heard all of the Audioquest cables, however.
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
I've heard that Blue Jeans cable does good network cabling, even supply a test result with the Ethernet cables you buy from them showing the performance they offer, worth at least a look in to.
Very interesting.... for the price quoted I would get it for a A/B comparison with what ever cable I decide to go with. -
I don't option to buy them? am I missing something? -
I've been eyeing these guys up for awhile now. I like their design strategy & business model plus the great reviews. Not prepared just yet to make a move but down the road I will give them an audition. The digital cable for sure.
http://darwincables.com/About.html -
I have a bunch of WireWorld usb cables that I sell, the starlight is the best out there for the money. I used this with the ps audio dac and found it to be one of the best. If you want the cost no object then the Platinum starlight is the best out there.
Big fan of my Black Cat Veloce SPDIF cable. I run it instead of USB to my DacMagic. I need to try a "better" usb cable as my generic USB cable causes static in my speakers whereas the SPDIF is dead quiet."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
DittoDan
I'm using the MIT lighting USB.
Cheers
Roger -
Try here:
http://www.ebay.com/itm/Acoustic-Revive-LAN-1-0PA-1-0m-real-audio-grade-LAN-cable-Brand-New-Limited-Sale-/321385078172?pt=LH_DefaultDomain_0&hash=item4ad40b1d9c
