PSW111 Subwoofer blows fuses
GedStankus
GedStankus Posts: 2
edited May 2014 in Troubleshooting
Hi there, I'm first time on the forum with just a question...
I was given a sound system which is about 6-7 years old and the subwoofer that came with it (PSW111) blows it's fuse as soon as it's turned on. I assume there's a short of some kind. Anyway, just wondering if it's worth fixing?
Post edited by GedStankus on
  • GedStankus
    GedStankus Posts: 2
    edited May 2014
    Oh, and the serial# is AM114502010 if that helps.
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited May 2014
    Hello,
    Welcome to Polk's forum. I believe Polk will service your amplifier for a reasonable amount. First thing tomorrow call Polk CS at 1-800-377-7655 and they'll give you the details.
    Regards, Ken
  • deafbykhorns
    deafbykhorns Posts: 150
    edited May 2014
    If its too expensive or obsolete, theres always Parts Express for a plate amp.
    Main System- Scratch built 2A3 , Lightspeed preamp, Technics SP15/Graham/XV1s,Klipschorns w/ALK xovers/Trachorns, Speakercraft MT8(4), Sonos ZP90, Yamaha Aventage for surround
    Office System- Adcom GTP500, Bedini 45/45,Lexicon RT-20,Enlightened Audio DAC, Polk SDA2.3TL, Northcreek Borealis
