what should i do?
Codeman
Codeman Posts: 14
edited May 2014 in Speakers
I am pretty happy with my home theater set up that I have right now but I want to timbre match everything.. I am considering going with the tsx440's for my towers but no sub or going with the tsx220 bookshelfs and 2 subs.. What would be a better buy?... I am about 50/50 on movies and music so.. Not sure what would be the best route to take.. Any opinions?
Samsung 51 inch plasma
Yamaha Aventage RX-A730
Onkyo Skf-4800 towers
Polk Tsx-150c center
Polk Tsx-110b rears
Twin Onkyo SKW-204's
Post edited by Codeman on
  • chumlie
    chumlie Posts: 8,658
    edited May 2014
    Get the 440's now and add a sub at a later date.
  • rooftop59
    rooftop59 Posts: 8,121
    edited May 2014
    I would highly recommend bookies and dual subs, especially if you're gong to get decent subs. Those towers won't go that low, even for music, but will especially be lacking on movies. However, before you go with dual subs make sure that you can properly set them up. You will want either a receiver with preouts or subs with speaker line level inputs. That way you can run stero LR subs, with one only having the signal for the left channel, and the other for the right. You will then use the built-in crossover in the sub to blend them properly with the bookshelves.
    Good luck!
    Game Room 5.1.4:
    Bedroom 2.1
  • Codeman
    Codeman Posts: 14
    edited May 2014
    rooftop59 wrote: »
    Good luck!
    Yea i really love the way my 110s are sounding.. for music they sound GREAT by themselves.. soo im guessing the 220s for up from will be great
    Polk Tsx-110b rears
  • Codeman
    Codeman Posts: 14
    edited May 2014
    Well I just placed an order for 2 brand new Onkyo SKW-204 subwoofers today!! I think they will do wonderfully with my set up.. My father has the 204 and that thing packs a punch and does it very clean. I opted for 2 mainly because of the visual effect but also to disperse the low end more evenly throughout my living room.. Cannot wait!!!
    Polk Tsx-110b rears
    F1nut Posts: 51,685
    edited May 2014
    You better start reading on how to set up and dial in 2 subs in a room.
  • deafbykhorns
    deafbykhorns Posts: 150
    edited May 2014
    What he said^
    Or get a couple of JL Audio fathoms with automatic room optimization
    Main System- Scratch built 2A3 , Lightspeed preamp, Technics SP15/Graham/XV1s,Klipschorns w/ALK xovers/Trachorns, Speakercraft MT8(4), Sonos ZP90, Yamaha Aventage for surround
    Office System- Adcom GTP500, Bedini 45/45,Lexicon RT-20,Enlightened Audio DAC, Polk SDA2.3TL, Northcreek Borealis
