what should i do?
I am pretty happy with my home theater set up that I have right now but I want to timbre match everything.. I am considering going with the tsx440's for my towers but no sub or going with the tsx220 bookshelfs and 2 subs.. What would be a better buy?... I am about 50/50 on movies and music so.. Not sure what would be the best route to take.. Any opinions?
Samsung 51 inch plasma
Yamaha Aventage RX-A730
Onkyo Skf-4800 towers
Polk Tsx-150c center
Polk Tsx-110b rears
Twin Onkyo SKW-204's
Polk Tsx-110b rears
Get the 440's now and add a sub at a later date.
I would highly recommend bookies and dual subs, especially if you're gong to get decent subs. Those towers won't go that low, even for music, but will especially be lacking on movies. However, before you go with dual subs make sure that you can properly set them up. You will want either a receiver with preouts or subs with speaker line level inputs. That way you can run stero LR subs, with one only having the signal for the left channel, and the other for the right. You will then use the built-in crossover in the sub to blend them properly with the bookshelves.
Good luck!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Good luck!
Yea i really love the way my 110s are sounding.. for music they sound GREAT by themselves.. soo im guessing the 220s for up from will be greatSamsung 51 inch plasma
Polk Tsx-110b rears
Twin Onkyo SKW-204's -
Well I just placed an order for 2 brand new Onkyo SKW-204 subwoofers today!! I think they will do wonderfully with my set up.. My father has the 204 and that thing packs a punch and does it very clean. I opted for 2 mainly because of the visual effect but also to disperse the low end more evenly throughout my living room.. Cannot wait!!!Samsung 51 inch plasma
Polk Tsx-110b rears
You better start reading on how to set up and dial in 2 subs in a room.
What he said^
Or get a couple of JL Audio fathoms with automatic room optimizationMain System- Scratch built 2A3 , Lightspeed preamp, Technics SP15/Graham/XV1s,Klipschorns w/ALK xovers/Trachorns, Speakercraft MT8(4), Sonos ZP90, Yamaha Aventage for surround
Office System- Adcom GTP500, Bedini 45/45,Lexicon RT-20,Enlightened Audio DAC, Polk SDA2.3TL, Northcreek Borealis
