Dawgfish loaned indefinitely a anthem amp2 that has a low level hum, help me
scottyboy76
scottyboy76 Posts: 2,905
edited May 2014 in Electronics
As usual. the bear of cp was loaded with gear when he came by to help me set up my pristine sda 1cs.
Ics, Tubes, as well as the anthem amp2, to match with my sonic frontiers sfl1 pre.
The only problem, small as it is, is a hum, hardly noticeable when no music is playing,
I have switched tubes to a gold prong, russian made he loaned me, no avail.
It is only noticeable during quiet, or silent pasages. but it is starting to get to me.
Have tried many ics, none to any available.
Any advice would be appreciated.
I have a carver tfm 25, which has no hum, but I dont believe has the balls this amp does, might be wrong.
Thanks again
scott and deb
humpty dumpty was pushed
Post edited by scottyboy76 on
  • Conradicles
    Conradicles Posts: 6,335
    edited May 2014
    Also email Chris @ Parts ConneXion if the cheater plug does not work. He may have an idea.
  • voltz
    voltz Posts: 5,384
    edited May 2014
    I had luck with a "Ebtech Hum X Voltage Hum Filter" I got from amazon but its like $50, but it solved a problem I had. So I'd try the others 1st.
    tonyb Posts: 33,068
    edited May 2014
    Is the hum coming from the speakers or the amp itself...with nothing connected to it ?
  • scottyboy76
    edited May 2014
    I think i have a cheater plug here somewhere, if im correct, it just allows you to plug a three prong plug in one end, and the other side has only the two blades, no round ground prong, right?
    the hum is coming from the speakers, not the amp or any other units.
    If the cheater does not work, will look into the other hum filter, thanks all.
    if all else fails, will have to unpile everything and put the carver back.
    BTW, any opinions on the quality, worthiness between the tfm25 and the anthem, kinda think i know the answer, but what the heck.
  • scottyboy76
    edited May 2014
    Cheater plug no workee, will be contacting the others you guys have directed me to.
  • scottyboy76
    edited May 2014
    Ok I just swapped the anthem out and the carver tfm 25 in.
    Sounds very different, dont want to say better, because that anthem has some real heft, but the carver is silent when it needs to be, and when cranked, more than holds its own.
    Still interested in what is causing the hum in the anthem.
    Let me tell you this, the anthem is one heavy ****,and not just compared to the carver, to me its a testament to bob carver that he could make an amp without the heft, and heat that still sounds so good.
  • deafbykhorns
    deafbykhorns Posts: 150
    edited May 2014
    What is your preamp?
    Main System- Scratch built 2A3 , Lightspeed preamp, Technics SP15/Graham/XV1s,Klipschorns w/ALK xovers/Trachorns, Speakercraft MT8(4), Sonos ZP90, Yamaha Aventage for surround
    Office System- Adcom GTP500, Bedini 45/45,Lexicon RT-20,Enlightened Audio DAC, Polk SDA2.3TL, Northcreek Borealis
  • scottyboy76
    edited May 2014
    My pre is a sonic frontiers sfl1
  • deafbykhorns
    edited May 2014
    Well, so much for my theory (impedance), that should be a good match with that amp.
  • drumminman
    drumminman Posts: 3,396
    edited May 2014
    Scotty, I had the same issue and this worked a treat for me. Take a piece of wire and connect the chassis of the pre to the chassis of the power amp. You can also connect the CDP if the hum is still present, though connecting just the two completely eliminated the hum for me. You can do it externally using the case screws as long as they're not painted or power coated.
    Differing ground potentials can cause this.
    Lifting the ground on the amp should only be a temporary solution as it's there for safety.
  • scottyboy76
    edited May 2014
    Thanks drum, I have put the carver in place, but i will keep that info filed away.
