pic test picture size
dkfreebirddkfreebird Posts: 1,130
edited June 2014 in Forum Testing Area
Trying to resize pics to fit
Polk 1.2tl's Fully modded with dreadnought
Rogue Atlas Magnum
Rogue Magnum 66
North Star Intenso Dac
Auralic Aries Mini Streamer
Marantz UD 7007
Pangea PC
Wireworld Equinox 7 interconnects
Wireworld Equinox 7 Speaker Cables and Jumpers
Home theater
Marantz SR 5009-B&W Cdm1nt, Cdm Center Channel
Backups Polk Monitor 5 peerless,2.3tl,SRS2 pin/blade,Polk Crs+ pin/blade with stands.McCormack Dna 0.5 Deluxe,Dared Sl 2000A,Dayens Ampino
Post edited by dkfreebird on
  • mhardy6647mhardy6647 Posts: 26,552
    edited April 2014
    pretty little.
    Flikr, at least, lets one decide what size to insert - from mild to wild :-)
    9598891997_cb427c3552_s.jpgDSC_5663 by mhardy6647, on Flickr
    9598891997_cb427c3552.jpgDSC_5663 by mhardy6647, on Flickr
    9598891997_cd4864cdcb_o.jpgDSC_5663 by mhardy6647, on Flickr
  • dkfreebirddkfreebird Posts: 1,130
    edited April 2014
    Thanks I will look into that.
    Rogue Atlas Magnum
    Rogue Magnum 66
    Marantz UD 7007
    Pangea PC
    Home theater
  • leftwinger57leftwinger57 Posts: 2,918
    edited April 2014
    Hey doc, just noticed that's my ADC 303ax there. The room has changed a bunch since this shot was taken with now w/ a new carpet and I have a line up of growing kids of the Klipscp sub behind the KLH#331>ADC 303ax>DCM TF 350s. I also have to check out the icon system on PhotoBucket because besides not even knowing how to size pics I never really played w/ the system besides the occasional post or two.
  • Mikey081057Mikey081057 Posts: 7,430
    edited April 2014
    Testing 1,2
    Garage | Polk Monitor 5B's
    edited May 2014
    Just trying to figure out flickr
    Rogue Atlas Magnum
    Rogue Magnum 66
    Marantz UD 7007
    Pangea PC
    Home theater
    edited May 2014
    It's a moving target :-)
    Basically, you want to use the BBCode option under "share this picture" -- it's real obvious from Flikr ;-) (no, it's not...)
    14174138442_cc5189013c_b.jpgFLIKR example 051314 by mhardy6647, on Flickr
    13960018899_4c3aedce23_b.jpgDSC_1369 by mhardy6647, on Flickr
    edited May 2014
    But how do you move it to here?
    Rogue Atlas Magnum
    Rogue Magnum 66
    Marantz UD 7007
    Pangea PC
    Home theater
    edited May 2014
    Don't move it - just highlight, copy and paste the link (it starts with "URL" in square brackets) into your post.
    In the case of the photo I added previously, the link and syntax looks like this (I had to modify it a bit for you to see the code):
    (open square bracket)url=https://flic.kr/p/ngAKg2](open square bracket)img]https://farm3.staticflickr.com/2927/13960018899_4c3aedce23_b.jpg(open square bracket)/img](open square bracket)/url](open square bracket)url=https://flic.kr/p/ngAKg2]DSC_1369(open square bracket)/url] by (open square bracket)url=https://www.flickr.com/people/[email protected]/]mhardy6647(open square bracket)/url], on Flickr
    where, of course "(open square bracket)" means the character "["
    edited May 2014
    Another try
    Rogue Atlas Magnum
    Rogue Magnum 66
    Marantz UD 7007
    Pangea PC
    Home theater
    edited May 2014
    14173514454_c225de48a2_n.jpgultra 06 by dkfreebird, on Flickr
    Rogue Atlas Magnum
    Rogue Magnum 66
    Marantz UD 7007
    Pangea PC
    Home theater
    edited May 2014
    you're there.
    me 'n the kittehz sez "congratulations" ;-)
    11946571403_495e2729a1_o.jpgtwocatsabed2 by mhardy6647, on Flickr
    edited May 2014
    THANKS FOR YOUR HELP I tried it once and kept seeing the entire paste in the reply line until I posted the reply and thought that the entire paste would be there including my email name(which really doesn't matter I guess)I really appreciate your help and is that all your gear on your flickr page?
    Rogue Atlas Magnum
    Rogue Magnum 66
    Marantz UD 7007
    Pangea PC
    Home theater
    edited May 2014
    de nada. Flikr is tedious enough (compared to, e.g., Photobucket) that it seems only sporting to try to help... the nice thing about Flikr is the 1TB bandwidth for free ;-)
    In answer to you question, no, not all of it - this, e.g., isn't mine...
    11322441483_f1a6c10f20_o.jpgDSC_5143 by mhardy6647, on Flickr
    Dandy stuff, though... the amplifier being used in that photo is a single-ended amplifier using a direct-heated triode tube called a 50. A pair of 50s today would probably cost as much as I have invested in my whole hifi :-)
    edited May 2014
    Yep a little steep for me but your scenery up there is awesome,I really enjoy your pics
    Rogue Atlas Magnum
    Rogue Magnum 66
    Marantz UD 7007
    Pangea PC
    Home theater
    edited May 2014
    dkfreebird wrote: »
    Yep a little steep for me...
    me, too - this is more my speed ;-)
    14191384744_4962c75899_o.jpgyorxie4 by mhardy6647, on Flickr
    9728329873_fe4ec855da_o.jpgpanasign1 by mhardy6647, on Flickr
    edited May 2014
    Mhardy. do you always have to delete your email address out of your pic post off flikr?
    Rogue Atlas Magnum
    Rogue Magnum 66
    Marantz UD 7007
    Pangea PC
    Home theater
    edited May 2014
    For better or worse, Flikr belongs to Yahoo. My user name is just "mhardy6647" at flikr (not my full e-mail address), so, no - I don't have to. I am assuming your full e-mail address is being used for your logon name(?).
    That said, one of my big peeves vis-a-vis Flikr is the fact that one can't set defaults; it would be nice to be able to customize size, caption information, syntax, etc. once and for all - and just copy the info with one click (a la Photobucket).
    But, I've gotta be honest... for a terabyte of free bandwidth, I'll put up with quite a bit! ;-)
    14031028000_a25e84af2a_b.jpgDSC_9291 by mhardy6647, on Flickr
  • avnerscavnersc Posts: 8
    edited May 2014
  • FrayDogFrayDog Posts: 36
    edited May 2014
    test <iframe src="https://www.flickr.com/photos/[email protected]/14065786728/in/photostream/player/&quot; width="75" height="75" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
    14065786728_496ecb31af_b.jpgStrung up by fraydog07, on Flickr
    Pioneer Elite VSX-82TXS
    Logitech Harmony One
    Sony bdp-s5100
    Klipsch RW12-D
    Polk Monitor 75T
    Polk CSI30
    Polk RT15
    Polk M20
    edited May 2014
    ... looks like a virtual deck(?)
    Good holiday weekend project.
    Which reminds me.., the rain's stopped; gonna go put the the flag out front.
  • lilylily608lilylily608 Posts: 15
    edited June 2014
  • Talon_SrTalon_Sr Posts: 125
    edited June 2014
    Test.
    Pioneer SC-1523-K and VSX-1018AH-K; Polk Monitor 75T Fronts, Pioneer S-HF11C Center, Cerwin Vega VE-5M surrounds and backs; Polk PSW-505 with Mediabridge SW cable; Onkyo SKW-204 with Mediabridge SW cable; Oppo BDP-103; Akai GX-255 Open Reel.
    edited June 2014
    not lookin' too promisin'...
Howdy, Stranger!
