Best place on the net to order supplys
Systems
Systems Posts: 14,872
edited August 2004 in Custom Fabrication
I'm looking to purchase grey carpet and the security screws to install my system. Any good sites?
Testing
Testing
Testing
  • neomagus00
    neomagus00 Posts: 3,899
    edited July 2004
    a home depot/lowes kind of place is good; www.crutchfield.com is good too for carpet, at least, i dunno about 'security screws'... if you mean carriage bolts or something of that sort, again, HD or lowes is good
  • [Deleted User]
    [Deleted User] Posts: 763
    edited July 2004
    selectproducts.com
    mcmaster.com
  • Jstas
    Jstas Posts: 14,997
    edited July 2004
    I've recently used mcmaster.com from a previous recommendation from Josh. Very good company, oodles of supplies too! Very professional. At least my small dealing with them was.
    Expert Moron Extraordinaire
  • Systems
    edited July 2004
    we use mcmaster for everything at where i work, wonderfull place, they have almost anything
    Testing
    Testing
    Testing
  • BassAce
    BassAce Posts: 12
    edited July 2004
    Partsexpress is a good place to order supplies. Partsexpress
    For security screws you can get security torx.
    security torx
    I recommend getting the free partsexpress catalog, it arrives in about three days.
  • neomagus00
    edited July 2004
    hey, that partsexpress (the middle part of the word just jumps right out at ya, doesn't it? :D) place has some cheap focal stuff, in case anyone cares...
  • BassAce
    BassAce Posts: 12
    edited July 2004
    Do you know where you can buy Focal car audio?
  • exalted512
    exalted512 Posts: 10,734
    edited July 2004
    cbrstereo.com is probably the cheapest you can find without a warranty besides going to ebay
    speedsound.com is probably the cheapest you can find warranted from Focal
    -Cody
  • MacLeod
    MacLeod Posts: 14,358
    edited August 2004
    Focal doesnt authorize any internet sales so if you buy off the net, regardless what the site claims, Focal will not honor the warranty.
    Speedsound is a real shop and is an authorized dealer but if you buy from them online you get no warranty.
    Focal is a real pain in the **** about this. JL and Diamond too.
