Need help quick-like!! 2006 Accord auto door opener fob and turn signal problem...
starkiller
starkiller Posts: 2,723
edited May 2014 in The Clubhouse
Just went out to my wife's Accord to get a book and noticed her right turn signal is flashing..well, very slowly flashing that is. Last time she was in the car was yesterday afternoon so I am guessing the battery is about toast. Tried two different fobs to open the doors and nothing. Tried the fob on the trunk release..nothing. Don't want to try a key in the lock as am afraid the alarm might go off which at this time of night would not be a good thing...
Thoughts??
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Post edited by starkiller on
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    edited May 2014
    Have your tools ready, and use the key to open door. If alarms goes off disconnect the battery.
    F1nut Posts: 52,005
    edited May 2014
    Using the key is not going to set off the alarm.
  • 20hz
    20hz Posts: 636
    edited May 2014
    if the factory alarm is set I would think using the key to open the door would set it off ?
    Sounds like the alarm was going off and now the battery is very drained .
    I am not a expert by far but have seen similiar on a vw I think the headlights were left on and when they turned off the ignitioin key they went off but the tailights were on and slowely killed the battery .
  • rooftop59
    rooftop59 Posts: 8,120
    edited May 2014
    In my Sequoia using the key does set off the alarm but putting the key in the ignition and turning without cranking turns if off. So u can stop it quick...
    Game Room 5.1.4:
    Bedroom 2.1
    Toolfan66 Posts: 18,189
    edited May 2014
    If the battery was/is almost dead, how loud do you think the alarm will really be?
    Also when you put the key in the door turn the key twice as you would to unlock it, that should disable the alarm. My Lexus was like this, haven't tried my Tacoma..
  • starkiller
    edited May 2014
    Thanks for the tips..am going out in a few minutes to see what's what :)
  • hochpt21
    hochpt21 Posts: 5,423
    edited May 2014
    Hope the OP figures it out.
    In a related note. My remote died for my Jeep. When I use the key to unlock the door, the alarm goes off until I can get the key in.
    I changed the battery on the remote and it worked once, but not again.
  • starkiller
    edited May 2014
    okie doke, opened the car door ok...attached the jumper cables from the portable battery starter I have, flicked the switch to on and the alarm went off. Tried again with the key in the door, turned twice, put key in ignition, turned the portable on..alarm went off. so did the key in the ignition, turned twice, then flicked the switch to on...whoo hoo, no alarm. But, portable battery was too low to charge so, brought my subie around, hooked up the jumpers and the Accord started and all is well. Drove it around for awhile and then parked and turned it back on and everything was fine.
    What happened was the GPS fell off the window right onto the hazards switch, they had been on for about 30 hours :)
    Thanks for the help everyone!
  • ViperZ
    ViperZ Posts: 2,046
    edited May 2014
    starkiller wrote: »
    Glad you figured it out!
    I thought such stuff only happens to PFB on this forum.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
