Need help quick-like!! 2006 Accord auto door opener fob and turn signal problem...
starkiller
Just went out to my wife's Accord to get a book and noticed her right turn signal is flashing..well, very slowly flashing that is. Last time she was in the car was yesterday afternoon so I am guessing the battery is about toast. Tried two different fobs to open the doors and nothing. Tried the fob on the trunk release..nothing. Don't want to try a key in the lock as am afraid the alarm might go off which at this time of night would not be a good thing...
Thoughts??
Thoughts??
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Post edited by starkiller on
Have your tools ready, and use the key to open door. If alarms goes off disconnect the battery.2-ch System: Parasound P/LD 2000 pre, Parasound HCA-1000 amp, Parasound T/DQ Tuner, Phase Technology PC-100 Tower speakers, Technics SL-1600 Turntable, Denon 2910 SACD/CD player, Peachtree DAC iT and X1asynchorus USB converter, HSU VTF-3 subwoofer.
Using the key is not going to set off the alarm.Political Correctness'.........defined
President of Club Polk -
if the factory alarm is set I would think using the key to open the door would set it off ?
Sounds like the alarm was going off and now the battery is very drained .
I am not a expert by far but have seen similiar on a vw I think the headlights were left on and when they turned off the ignitioin key they went off but the tailights were on and slowely killed the battery . -
In my Sequoia using the key does set off the alarm but putting the key in the ignition and turning without cranking turns if off. So u can stop it quick...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
If the battery was/is almost dead, how loud do you think the alarm will really be?
Also when you put the key in the door turn the key twice as you would to unlock it, that should disable the alarm. My Lexus was like this, haven't tried my Tacoma.. -
Thanks for the tips..am going out in a few minutes to see what's what
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC -
Hope the OP figures it out.
In a related note. My remote died for my Jeep. When I use the key to unlock the door, the alarm goes off until I can get the key in.
I changed the battery on the remote and it worked once, but not again.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
okie doke, opened the car door ok...attached the jumper cables from the portable battery starter I have, flicked the switch to on and the alarm went off. Tried again with the key in the door, turned twice, put key in ignition, turned the portable on..alarm went off. so did the key in the ignition, turned twice, then flicked the switch to on...whoo hoo, no alarm. But, portable battery was too low to charge so, brought my subie around, hooked up the jumpers and the Accord started and all is well. Drove it around for awhile and then parked and turned it back on and everything was fine.
What happened was the GPS fell off the window right onto the hazards switch, they had been on for about 30 hours
Thanks for the help everyone!Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC -
starkiller wrote: »
Glad you figured it out!
I thought such stuff only happens to PFB on this forum.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
