life after tubes?
sucks2beme
So I've been mulling over making life simple.
Part of that is going to a SS integrated instead of a tube amp/preamp.
AM I crazy? I'm willing to give up a bit of sound quality for just turning stuff
on and off. And NOT getting easy baked while listening to music.
Post edited by sucks2beme on
Can you really go wrong either way?
My Vincent pre-amp & Amp are both Hybrid's with tubes in the input and output stages. I really love there sound.2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
There's some fine sounding solid state stuff - dollar for dollar, IMO, you get more bliss for your Gelt from vacuum tubes, though.
I don't have any trouble turning stuff on and off -- two switches takes care of mine (the hifi circuit's on a switch - but I turn on the power amp itself separately).
Yeah, heat can be an issue -- it's not too bad with a SE 2A3 power amplifier, and a very simple, two-tube (low voltage) preamp. The vacuum tube tuner doesn't put out much heat -- and everything else's soiled state.
So, I vote, no, you're not crazy.
Is this a poll?
life after tubes...... is no life at all? Did I get it right? Do I win a prize?
mhardy, can I blame you? After reading the vintage thread, I bought the 1150 Marantz.
That sounded good enough to get me thinking. It was better than any other vintage piece
I've run through here. And the question became, could I live with a decent SS
integrated? The answer seems to be yes."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
You can take my tubes when you can pry them from my cold, dead hands.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Yes, indeed there is.Political Correctness'.........defined
President of Club Polk -
Not sure my brain can handle a rig without ANY tubes in it. It's a question of balance; SS/tubes
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
Just went from a tube integrated that I've had in the system for 8yrs to a DAC/Pre and Parasound A21. Not feeling too sorry at all :^ )2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
I like tubes just fine in the signal chain, but not providing the power. I require solid state power.
Two Channel Setup:
Speakers: Wharfedale Opus 2-3
Integrated Amp: Krell S-300i
DAC: Arcam irDac
Source: iMac
Remote Control: iPad Mini
3.2 Home Theater Setup:
Fronts: Klipsch RP-160M
Center: Klipsch RP-160M
Subwoofer: SVS PB12NSD (X 2)
AVR: Yamaha Aventage RX-A2030
Blu Ray: Sony BDP-S790
TV Source: DirecTV Genie -
Life after tubes ? Sure there is.
I started off in tubes, went SS, and now wanted some flavor of both. SS has come along way since the 70'S in SQ....so have tubes too. I get where your coming from on the simplicity, too many tubed pieces becomes like spinning vinyl, a headache. Too many variables that can play havoc on the sound.
Tubed pre's and SS amps seems to be the happy medium for a lot of folks. I have a tube hybrid amp and can't decide on a tube pre or SS myself.HT SYSTEM-
lsi 9's -
Tube pre-amp, SS amp will give you best of both worlds you are looking for. Tube pre's are easy peasy.
I agree, tube pre and SS amp, and I have settled on that combo for the living room and the mancave systems.
Unless you have lots of extra money for equipment, tube replacement, and energy. Or you need to heat a room.Norh ACA-2B tube pre, Sumo Andromeda SS amp. Magneplanar MMG speakers, M&K MX1250 Subwoofer, Pro-Ject RM1.3 Genie TT with Sumiko Pearl MM cart., Keces DAC, Cambridge Audio Azur 640c CD player -
You could always go with an integrated with tubes built in, like a Peactree Nova125 that has a tube buffer + icepower amps.
sucks2beme wrote: »mhardy, can I blame you? After reading the vintage thread, I bought the 1150 Marantz.
Did I explicitly recommend a Marantz 1150?!? If so, I musta been eatin' the brown acid. Glad you like it, though ;-) -
Don't know why you would consider moving to SS "giving up a bit of sound quality."Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
I think he was simply suggesting that he prefers the sound of tubes over SS.HT SYSTEM-
lsi 9's -
Good gear is good gear. SCompracer has done the tube thing, and now is all soiled state--I don't think you'll find him saying he's missing anything he had before, and in fact I think he's as happy as he's been. Someone tried to tell him that his system must somehow be lacking without some glass in it--I'll attest to the fact that that statement is hogwash, painted with way too broad a brush.
I say this as the very happy owner of a Manley Shrimp tube pre myself!Jay
Well then you can't possibly be happy, and since we live fairly close I'd be happy to come pick it up before you toss in the dumpster. LOL
This whole tube vs. SS thing is stupid. Everone has different tastes in both camps and neither is rendered any less superior than the other. The OP simply claimed his preference for tubes and is under the impression SS can't compete. It's up to you guys to steer him to the right pieces to change that perception.HT SYSTEM-
lsi 9's -
mhardy6647 wrote: »Did I explicitly recommend a Marantz 1150?!? If so, I musta been eatin' the brown acid. Glad you like it, though ;-)
Not specificly, I did however run through a couple of others as well. The Marantz seems to like the Proacs.
The others, not so much."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
ahh... that sort of thing definitely does happen. I was quite surprised to discover empirically my good ol' Polk Audio Monitor Series Model 7A did not sound very nice at all driven by an EICO HF-81 (pp EL84 stereo integrated amplifier).
The ARC vt60 is a hard act to follow. There are SS amps I'm sure can match it,
just NOT within the budget. The vt60 used was a rare find. Most stuff with the ARC
label are $$$$$$$.
As far as the Marantz goes, I'm sure that part of why it works so well in the system is
the fact the amp section is in pretty good condition. DC offset and idle current don't drift at all.
set it and it stayed PUT. Not like some other older stuff that's been through here.
The 1150 is a bit different than the other Marantz stuff I've had as well. If memory
serves me right, that was the case back in the 70's as well. I'm sure a Sansui au-719
would be a good choice as well, if one that wasn't dipped in gold could be found.
(not literally, but given their asking prices, sure could be)."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
I would love an old Sansui Au-717-719 myself. Some of those old integrateds were built like a tank. Still, for what people are asking for them, they can't hold a candle to a used Parasound or B&K amp for roughly the same price....and 30+ years newer to boot.
The Arc is a nice amp, but a McCormack might change your thinking on SS power...and give you more options on speakers.HT SYSTEM-
lsi 9's -
I like Peachtree products a lot for a good integrated. Very warm and musical, tube pre and great dac.
There's definitely life after tubes. I was hardcore tubes for the past 11 years until 2 weeks ago when I got a ss receiver that has a sound signature I really dig. I don't miss tubes at all. Though the cdp I'm using at the moment has a tube buffer stage.
Good sound is good sound. Doesn't matter if it's coming from ss or tubes. -
....Duplicate post, lol"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
