Best place on the net to order supplys
Systems
I'm looking to purchase grey carpet and the security screws to install my system. Any good sites?
Testing
Testing
Testing
Testing
Testing
a home depot/lowes kind of place is good; www.crutchfield.com is good too for carpet, at least, i dunno about 'security screws'... if you mean carriage bolts or something of that sort, again, HD or lowes is goodIt's not good, very fundamentally simply not good. - geolemon
selectproducts.com
mcmaster.com -
I've recently used mcmaster.com from a previous recommendation from Josh. Very good company, oodles of supplies too! Very professional. At least my small dealing with them was.Expert Moron Extraordinaire
we use mcmaster for everything at where i work, wonderfull place, they have almost anythingTesting
Testing
Testing -
Partsexpress is a good place to order supplies. Partsexpress
For security screws you can get security torx.
security torx
I recommend getting the free partsexpress catalog, it arrives in about three days. -
hey, that partsexpress (the middle part of the word just jumps right out at ya, doesn't it?
) place has some cheap focal stuff, in case anyone cares... It's not good, very fundamentally simply not good. - geolemon
Do you know where you can buy Focal car audio?
cbrstereo.com is probably the cheapest you can find without a warranty besides going to ebay
speedsound.com is probably the cheapest you can find warranted from Focal
Focal doesnt authorize any internet sales so if you buy off the net, regardless what the site claims, Focal will not honor the warranty.
Speedsound is a real shop and is an authorized dealer but if you buy from them online you get no warranty.
Focal is a real pain in the **** about this. JL and Diamond too.polkaudio sound quality competitor since 2005
![[Deleted User]](https://forum.polkaudio.com/applications/dashboard/design/images/banned.png)
