keep searching but not finding safe temp for xover soldering
BKphoto
I have a digital soldering station....what approx. temp is safe for the crossover....
Do you have a "rule of thumb"
Marantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's
Post edited by BKphoto on
Will depend on the solder you use, as they have different melting points. I don't have a digital one, so can't get you a number idea. It seems to me that higher temperatures (within reason) are better as they will heat the board/leads to/past the melting temp of your solder faster. Less time with heat on the work = better/safer for the components. Use a heat sink on the leads of resistors/caps for additional peace of mind. Remember that the component leads and board trace are heated directly, and not the solder.
The good news for novice solderers (of which I am one!) is that crossover work is less delicate than PCB board-work on an amp, preamp, or source. Wider spacing of components, hardier traces that are less prone to lifting.
If someone more experienced than I sees I've given any bad info here, feel free to put me in my place. :razz:Jay
750 should do if your equipment is quality.
thanks...perfect...Marantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's
Jay is correct! Novice, I don't think so.....
A chart showing melt temps of various alloys. My personal fav is Cardas Tri-Eutectic. Lead free is good for the environment going green and all, but if you ever have to de-solder a RoHS compliant solder, have a good desoldering pump like a Hako 808 handy.
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
using desoldering iron...i like because its all in one hand...
soldering iron is a Hakko FX-888D
my garage is finally warm enough to work in...
100 posts!Marantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's -
with all soldering projects it's best to start at 650 and work your way up if you do not get proper flow. Make sure not to apply pressure and count your dwell time. 5-8 seconds. If you don't get proper flow in that time up your temp to 700 then 750 ect. Tip size is important as well. If your tip is to small you will require more heat (bad), to big and you will also cause damage. Most electronic projects I use a 2.4 tip. For smaller parts 0402's I go smaller. Flux is your friend. Just be sure to clean it after. For a nice solder joint remember less is more ! you don't want a big glob of solder. Just enough so you have a nice fillet.
Hope that helps.
Journeyman electronics solder monkey. -
Hey BK
I was thinking of trying some DIY kits, and getting Hakko FX-888D, and using some Kester 44 Rosin Core Solder 63/37 .031 for kits like the Bottlehead Crack amp, and picking up a 2.4 chisel tip? hows a set up like that sound?
I do plan on a lot of practicing with the soldergun before i try it for real though
That's the set up I use.
Yeah we are in the same boat...
I'm back to practicing to refine my technique more because my next project will be my amp...
not as forgiving as a speaker crossover...Marantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's -
Thanks all
I saw a video of someone making the bottlehead crack amp and think he said he was using 700 also.2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
Yea I watched that video, he does a pretty nice job. A couple small things to aim for when learning to solder is not to use as much solder as he does. When you tin your wires you want to do it so the lay of the wires is discernible in the solder and when you terminate them you should also be able to see it. Make sure after you terminate there is a 100% fillet between the wire and terminal when you are done. Around 14 min into the video he bends his wires connecting to the connector. This is a big no no. Have them come strait out of the connector. Once soldered hold your needle nose pliers where the wire connects and gently bend the wire around it leaving a small service/stress relieve loop. Is this all a little bit anal for this project ? Probably. But why not aim for class 3 (military,medical) required solder joints. Not only that but typing this out at work is a great time killer if anyones actually interested
ohh and before I forget, a nice trick for soldering those types of connectors is cut a small piece of solder and lay it beside your wire inside the terminal. Add some flux and heat it from the back with a dry iron and you will have a perfect joint. -
very interested, maybe we need a thread for Soldering: Tips & Hints
keep these coming...Marantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's -
Here is a link with pictures and criteria for pretty much any type of connection you can think of.
http://selteka.balt.net/x/LINPRA_mokymai_S.7.1/Reikalavimai%20PCB/IPC_Standartai/IPC-A-610D_Acceptability_of_Electronic_Assemblies.pdf
Making your joints look like the ones in the pictures is just a matter of flux and practice now. You have all the right tools. Remember to clean your tip with the sponge or brass scrunchy every time you make a connection. And tin when you are not using it. Your tips will last longer and make clean joints. Hold the iron like you would hold a pen, apply no more pressure then that and count your dwell time 5-8 seconds. -
I downloaded that PDF to my hard drive
