Inexpensive Learning/Universal Remote
xsmi
Hi guys I need a little help. I have an Integra 5.8 receiver that does not respond to ANY of the manufacturers codes for my U-Verse. I only want to be able to turn the unit on/off, control the volume and change input (Cable/Dish, Game etc.) I'd like to spend less than $50 so I think the Harmony Line is out.
2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
Post edited by xsmi on
Actually not necessarily on teh harmony. I got this for the bedroom:
http://www.ebay.com/itm/N-Logitech-915-000159-Harmony-650-Advanced-Universal-Remote-Control-/111257960570?pt=US_Remote_Controls&hash=item19e77dc07a
I actually found a refurb for 40 on ebay, but don't see any new or refurb that cheap right now. Its a great little remote!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Not all codes are listed. Read the instructions and you should be able to set the remote to search. It will automatically search all codes and when the Integra turns off, you have to pay attention and hit the enter button quickly. I believe it's the same remote as Comcast uses.HT SYSTEM-
lsi 9's -
Older Harmony 520 or 550Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
You can pick up brand new harmony 600's on ebay for like 20 bucks. I've got one for my system and it works great! I have a Samsung TV, Onkyo tx-nr515, xbox one, and a raspberry pi running raspbmc running off of it.
http://www.ebay.com/itm/logitech-harmony-600-/390830471897?pt=US_Remote_Controls&hash=item5aff4fbad9 -
Here's a buy-it-now:
http://www.ebay.com/itm/Logitech-Harmony-600-Universal-Remote-Control-/111331942390?pt=US_Remote_Controls&hash=item19ebe69ff6Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Tried that as well. No go.
2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout. -
Thanks. I got it ordered.2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout. -
Double Post2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
