Inexpensive Learning/Universal Remote
xsmi
xsmi Posts: 1,801
edited April 2014 in Electronics
Hi guys I need a little help. I have an Integra 5.8 receiver that does not respond to ANY of the manufacturers codes for my U-Verse. I only want to be able to turn the unit on/off, control the volume and change input (Cable/Dish, Game etc.) I'd like to spend less than $50 so I think the Harmony Line is out.
2-channelBelles 22A Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
Post edited by xsmi on
  • rooftop59
    rooftop59 Posts: 8,121
    edited April 2014
    Actually not necessarily on teh harmony. I got this for the bedroom:
    http://www.ebay.com/itm/N-Logitech-915-000159-Harmony-650-Advanced-Universal-Remote-Control-/111257960570?pt=US_Remote_Controls&hash=item19e77dc07a
    I actually found a refurb for 40 on ebay, but don't see any new or refurb that cheap right now. Its a great little remote!
    Game Room 5.1.4:
    Bedroom 2.1
    tonyb Posts: 33,069
    edited April 2014
    xsmi wrote: »
    Not all codes are listed. Read the instructions and you should be able to set the remote to search. It will automatically search all codes and when the Integra turns off, you have to pay attention and hit the enter button quickly. I believe it's the same remote as Comcast uses.
  • ViperZ
    ViperZ Posts: 2,046
    edited April 2014
    Older Harmony 520 or 550
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • TurboGTU
    TurboGTU Posts: 187
    edited April 2014
    You can pick up brand new harmony 600's on ebay for like 20 bucks. I've got one for my system and it works great! I have a Samsung TV, Onkyo tx-nr515, xbox one, and a raspberry pi running raspbmc running off of it.
    http://www.ebay.com/itm/logitech-harmony-600-/390830471897?pt=US_Remote_Controls&hash=item5aff4fbad9
  • rooftop59
    edited April 2014
    Game Room 5.1.4:
    Bedroom 2.1
  • xsmi
    xsmi Posts: 1,801
    edited April 2014
    tonyb wrote: »
    Tried that as well. No go. :/
  • xsmi
    xsmi Posts: 1,801
    edited April 2014
  • xsmi
    xsmi Posts: 1,801
    edited April 2014
    Double Post
