Reducing pic sizes for posting
hotwheelman
hotwheelman Posts: 1,300
How in the world do you reduce pic size so that they can be posted?
"Its worked so far but we're not out yet."
"Hey big man let me hold a dollar"
  • Demiurge
    Demiurge Posts: 10,874
    edited July 2004
    Photoshop, if you have it. That's what I use.
  • faster100
    faster100 Posts: 6,124
    edited July 2004
    Microsoft photo editor if you have office
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • hotwheelman
    edited July 2004
    Wonder if I can set the cam up to size these to what I need so that I don't have to go through a bunch of crap to resize them?
  • Pauly
    Pauly Posts: 4,519
    edited July 2004
    if i have a pic that is just over the top of the limit i'll trim it up (crop) in paint. If its a .jpg just to a save as .bmp
    Life without music would
  • hotwheelman
    edited July 2004
    Well, now I can post the pic as I have it resized and tested in the forum testing area. But now it will not let me post the image again even after I renamed the image.....damiiiiiiit. Justin please fix this so that if someone just needs to test to see that an image will post that they are not screwed when they try to post it in a normal thread...jeeeeez. I wrote my post three freakin times and not I will have to do it a fourth.
  • spyderman
    spyderman Posts: 678
    edited July 2004
    Hotwheel,
    I think Justin is tryin' to save space on his server. Can you link the original?
    If not, go back and change the size from the original that you posted and the pic will go through.
    RTi70 Fronts
    CSi40 Center
    RTi38 Rear
    PSW650 Sub
    Str-de1075 Receiver
    Hope is on the way!
    ABB
  • hotwheelman
    edited July 2004
    Oh I finally figured out what to do, I just went back and did an edit and deleted the image in question........I'm just one big brain **** tonight.
  • spyderman
    edited July 2004
    Nah, I struggled with that one until I figured out why I couldn't repost the same image twice. Instead of deleting the original pic in the original post, I would just change the size of the pic in MS, and then repost. It would save time trying to hunt down the original post.
    Good luck.
    RTi70 Fronts
    CSi40 Center
    RTi38 Rear
    PSW650 Sub
    Str-de1075 Receiver
    Hope is on the way!
    ABB
