Reducing pic sizes for posting
hotwheelman
How in the world do you reduce pic size so that they can be posted?
"Its worked so far but we're not out yet."
"Hey big man let me hold a dollar"
Photoshop, if you have it. That's what I use.
Microsoft photo editor if you have officeMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
Wonder if I can set the cam up to size these to what I need so that I don't have to go through a bunch of crap to resize them?"Its worked so far but we're not out yet."
"Hey big man let me hold a dollar" -
if i have a pic that is just over the top of the limit i'll trim it up (crop) in paint. If its a .jpg just to a save as .bmpLife without music would♭
Well, now I can post the pic as I have it resized and tested in the forum testing area. But now it will not let me post the image again even after I renamed the image.....damiiiiiiit. Justin please fix this so that if someone just needs to test to see that an image will post that they are not screwed when they try to post it in a normal thread...jeeeeez. I wrote my post three freakin times and not I will have to do it a fourth."Its worked so far but we're not out yet."
Hotwheel,
I think Justin is tryin' to save space on his server. Can you link the original?
If not, go back and change the size from the original that you posted and the pic will go through.RTi70 Fronts
CSi40 Center
RTi38 Rear
PSW650 Sub
Str-de1075 Receiver
Hope is on the way!
ABB -
Oh I finally figured out what to do, I just went back and did an edit and deleted the image in question........I'm just one big brain **** tonight."Its worked so far but we're not out yet."
Nah, I struggled with that one until I figured out why I couldn't repost the same image twice. Instead of deleting the original pic in the original post, I would just change the size of the pic in MS, and then repost. It would save time trying to hunt down the original post.
Good luck.RTi70 Fronts
CSi40 Center
RTi38 Rear
PSW650 Sub
Str-de1075 Receiver
Hope is on the way!
ABB
