Rta 15
  • nohalfstephen
    nohalfstephen Posts: 24
    edited April 2014
    Thanks for all of the info and advice! Hopefully I can find something budget friendly, if there is such a thing.....
  • HTguru1982
    HTguru1982 Posts: 1,066
    edited April 2014
    Adcom 535 and 545 would also work very well. Not as much as power as the 555 but are much cheaper. The 535's usually go for $100-$150. Should be plenty of them on Ebay.
    Display: Sony 42" LCD
    Sources: Harman Kardon DVD-27,
    Panasonic DMP-BDT110 blu ray player
    AVR: Sony STR-DA2400ES
    Amps: Sonance Sonamp 260(fronts),
    Kenwood KM-894(surrounds)
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
    Surrounds: NHT Super One
    Subwoofer: SVS PB10-ISD
  • nohalfstephen
    edited April 2014
    Will a Yamaha MX630 or MX 830 suffice? I seen a couple of them on ebay 1 for 150 and the other for 250.
  • Mystery
    Mystery Posts: 2,546
    edited April 2014
    Adcom's don't have speaker protection relay and many don't use them for that reason but mine's are working so far without any blown speakers.
  • igotitiscool
    igotitiscool Posts: 2
    edited June 2014
    which is a better speaker SDA 1A's or RTA 15's i have a chance of getting one or the other or both sets, and what should i pay of each set
