Burning DVDs on the PC
What model number ? Do you still have the owners manual ?Originally posted by exalted512
the one in the living room is GE -
ge1106p...looking for info in the user guide now
couldnt find anything
when i first open up dvd shrink to burn
it says:
this dvd appears to be RCE protected
if you correctly specify the region for which this dvd was intended, dvd shrink will remove the rce protection
if you leave the rce coding unmodified, this dvd will not play in a region-free dvd player or a player with region code other than the intended region
when i burned it...i clicked specify region, then USA, Canada
i dunno if that makes a difference?
I suspect that model does NOT play DVD+RW's ... In looking at the details for GE players I don't see any that do ...
welllllll ****
do you think an xbox will?
http://www.videohelp.com/dvdplayers.php?DVDname=ge1106p&Submit=Search&Search=Search&country=&orderby=Name
It would appear it can play DVD-R, DVD+R, VCD & SVCD
and you thought vhs .vs. beta was a problem ... -
so it might not be the DVD...but the DVD player...correct?
ok....my klh model number is kd-1220 and from that website it says it will read dvd+rw's
It would appear to be a media / player incompatibility ...
And does it ?Originally posted by exalted512
it said 'bad disk' when i tried:(Music is like candy, you have to get rid of the rappers to enjoy it
ive come to the conclusion that the world hates me;)Music is like candy, you have to get rid of the rappers to enjoy it
I am using a KHypermedia DVD+R burner $100 plus 100 free DVD's and having no trouble what so ever burning movies. I have done over 50 in the last 2 weeks or so. Gotta love Block Buster for their Unlimited Rental for 14.95. I use DVD shrink and only leave 5.1, it works fine in 2 ch mode for my Sony and Mit DVD players. I only record the movie nothing extra unless it all fits. The only reason i am doing this is incase BB burns down and i will have backups for them. This is not for personal use or sale:)Receiver Yamaha 3070 *Emotiva xpa5 * Behringer iNuke 6000dsp *Monster Cable HTS 3500 -- line conditioner * Panamax 5300 * Apple 4K * Panasonic UB820 * JVC NX5 * Silver Ticket thin bezel 120”
LSIM - Fronts 707 * Center 706c * Sides 702 * Rear 703 *FP RC85i * RP RC65i * Sub (2) SI HT18 -
lol...rub it in will ya?:D
it says **** on the file, i click it...it says please insert sonic disc...i have 2 from dell...put in one...didnt work...put in the other...didnt work
i called dell...talked to one person who sent me to another...24 minutes later i talked to him...he does not deal with XPS systems so he sent me to another...1 minute later while i was on hold it hung up on me
im pissed--im calling dell again in a little while so i have time to cool off before i rip someone a new one
I'm sure Dell will help you out if you just explain that you had to backup **** and now it won't play...
DVD shrink works fine for me, so unless you took something out that you shouldn't've, it should work for you. The fact the the drive that burnt the DVD will not read it tells you that it's not a media compatibility problem. The disc is a coaster, plain and simple.Ludicrous gibs! -
im going to call dell again now...i really hope i dont have to wait so long...
well
called dell back
24 minutes on hold this time
talked to the lady for about 20 minutes
she couldnt figure out my problem
so she sent me to some other guy
that guy immediately went to send me to another guy
in the process...i got hung up on again
i was on the phone for 46 minutes and have nothing to show for it
hell
ive been trying to get this **** work since 5 and have nothing to show for it...
wonderful
i keep getting errors with dvd shrink, how do you work this program? I mean open it up and then do what? click analize? uncheck everything you dont want? and then what? how do you save from dvd to disk?? HelpMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
Ludicrous gibs!
Freeware doesnt always have a help section, in the program anyways... So i did find the online help section... figured it out.. however after it starts authoring, minute later it says cant do because copy protection.. I thought this program got around that? I guess thats my real questionMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
It should. Try DVD Decrypter or check your program version. Did you get it from dvdshrink.org?Originally posted by faster100
Freeware doesnt always have a help section, in the program anyways... So i did find the online help section... figured it out.. however after it starts authoring, minute later it says cant do because copy protection.. I thought this program got around that? I guess thats my real question -
this is the message i get.. 72% done toMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
Have you tried with more than one disc? Try DVD Decrypter, it usually rips better than DVD Shrink (although I haven't had to use it for a while).Originally posted by faster100
this is the message i get.. 72% done to -
are you compressing the DVD at all. You will get that error is you excede the amount of space on the blank dvd. Always leave it to automatic on the movie.Receiver Yamaha 3070 *Emotiva xpa5 * Behringer iNuke 6000dsp *Monster Cable HTS 3500 -- line conditioner * Panamax 5300 * Apple 4K * Panasonic UB820 * JVC NX5 * Silver Ticket thin bezel 120”
Shouldn't do that if he is putting it into HD first. Also the original disc might be unreadable.Originally posted by jeremie
are you compressing the DVD at all. You will get that error is you excede the amount of space on the blank dvd. Always leave it to automatic on the movie. -
does someone have nero 6 full version they would like to burn for me and lemme demo.. DVD decrypter works only My nero program says it will only work with the drive (cdr) that it was bundled with... Its not a full retail version... help me here i have a headache from this thingMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
Download the latest demo from nero's website.
I dont want a demo that runs out, i have nero 5.5.... if someone has 6 they want to let me borrow let me know... ThanksMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC
