Surprised to get SACD playback
Loud & Clear
Yesterday I tried an "SACD only" disc, expecting to be greeted with silence. Didn't happen.
I hooked up a Sony BDP-S570 via coaxial to a Peachtree DAC iT X and inserted a Boston SACD (SACD only, not a hybrid). It played, and better than I've heard it before through the internal conversion of any of the players I've used before (Oppo, Sony). I assume it's being downmixed to PCM, although I'm not sure of the bitrate or frequency. The dac really brought these songs to life. Again, I didn't expect to hear any sound at all. I'm still not sure what's happening. But I like it and look forward to playing some of the other SACDs in my collection.
Two Channel Setup:
Speakers: Wharfedale Opus 2-3
Integrated Amp: Krell S-300i
DAC: Arcam irDac
Source: iMac
Remote Control: iPad Mini
3.2 Home Theater Setup:
Fronts: Klipsch RP-160M
Center: Klipsch RP-160M
Subwoofer: SVS PB12NSD (X 2)
AVR: Yamaha Aventage RX-A2030
Blu Ray: Sony BDP-S790
TV Source: DirecTV Genie
Post edited by Loud & Clear on
I think his point is that he has it connected via Coax, which most SACD players require analog output.Family Room HT 7.2/i]:Vizio Oled55h1 Pioneer Elite SC-LX502 Pioneer Elite BDP 85FD Eversolo DMP A6 Panamax M5300-EXSpeakers Fronts Fluance XF8L Center Polk Audio S35 Side Surrounds Fluance bipolar Rear Surrounds FluanceXF8 Bookshelf Subs SVS PB4000 x2 Living room 2ch: Crown Xli 1500 amp x2, Teac EQ MKII FX Audio X6 Mk II DAC Squeezebox Touch Polk Audio R700 Speakers Panamax M5100-EXOffice media room:Vizio M50Q6 50" Pioneer Elite VSX LX301 Eversolo DMP-A6 Polkaudio R600 Towers Polkaudio Center R350 Panamax M4300 Monoprice 12" subMaster bedroom:Vizio M55Q7 Pioneer Elite VSX LX302 Pioneer Elite BDP 85FD Squeezebox Touch Fluance Signature Bookshelf fronts, Rears Fluance Signature Bipolar Polk Audio CS10 center Monoprice 12" sub Panamax M5300-EX
I believe when connected with coax, the SACD player uses a down mixed stereo signal. It may be better than what your used to, but it's not giving you the full benefit of SACD.HT SYSTEM-
lsi 9's -
Is it passing 24/96? Whatever it's doing is pleasing to my ear. My only experience with SACD players are the Denon 2200, a few of the Sony BDP's, and an Oppo DV-980H. This downmix into DAC presentation is more lively and dynamic sounding. Details jump out and demand attention. I'm going to roll with it.
Two Channel Setup:
DAC: Arcam irDac
Source: iMac
TV Source: DirecTV Genie -
Most all of the higher model Sony Blu-ray Players will play SACD, the reason I selected Sony over the other brands.POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
To be fair, neither is that sony via analog.
That's the point. If you don't have a nice SACD player but want to enjoy your SACDs, and have a blu ray player and decent DAC, you can use the method I'm using for better results. Maybe there aren't a lot of people who find themselves in a similar situation, but if they are they can experiment with this and hear for themselves. Oh, and to correct myself, it's the Sony BDP-S580, not S570. It's possible that they behave differently.
Two Channel Setup:
DAC: Arcam irDac
Source: iMac
Loud & Clear wrote: »I assume it's being downmixed to PCM, although I'm not sure of the bitrate or frequency.
SACD's copyright protection prohibits full resolution audio via S/PDIF. You are correct, it's dithered down PCM or LPCM. The L being quantization levels are linearly uniform where PCM quantization levels vary as a function of amplitude. Or something like that. Or they are the same. I'm buzzed ...lol
avs forum has a huge thread on your player. Lots of pages, might be some grains of specifics in there for you.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
SCompRacer wrote: »SACD's copyright protection prohibits full resolution audio via S/PDIF. You are correct, it's dithered down PCM or LPCM. The L being quantization levels are linearly uniform where PCM quantization levels vary as a function of amplitude. Or something like that.
Thanks. Figured you'd know the details within the details ;>).
It's pleasing enough that I don't feel like I would need an HDMI input or DSD decoding capability when searching for a future DAC. Some type of readout would be nice, though. I'd like to be able to tell the bit rate and frequency that the DAC is receiving. Neither blu-ray player nor DAC will tell me what's being sent or received. How rude.
Two Channel Setup:
DAC: Arcam irDac
Source: iMac
Somebody knows, they just aren't tellin...lolSalk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
Tried a DVD-A disc. Readout indicated the output was 24/96 LPCM. Next I'll try a 24/192 DVD-A disc and see what it says.
When I played the SACDs, it just said "Two Channel DSD." But I'm guessing it just assumed that I was using the analog outputs instead of coaxial digital, so I don't know what it outputs via coaxial.
Two Channel Setup:
DAC: Arcam irDac
Source: iMac
