Surprised to get SACD playback
Loud & Clear
Loud & Clear Posts: 1,538
edited April 2014 in Electronics
Yesterday I tried an "SACD only" disc, expecting to be greeted with silence. Didn't happen.
I hooked up a Sony BDP-S570 via coaxial to a Peachtree DAC iT X and inserted a Boston SACD (SACD only, not a hybrid). It played, and better than I've heard it before through the internal conversion of any of the players I've used before (Oppo, Sony). I assume it's being downmixed to PCM, although I'm not sure of the bitrate or frequency. The dac really brought these songs to life. Again, I didn't expect to hear any sound at all. I'm still not sure what's happening. But I like it and look forward to playing some of the other SACDs in my collection.
Two Channel Setup:
Speakers: Wharfedale Opus 2-3
Integrated Amp: Krell S-300i
DAC: Arcam irDac
Source: iMac
Remote Control: iPad Mini
3.2 Home Theater Setup:
Fronts: Klipsch RP-160M
Center: Klipsch RP-160M
Subwoofer: SVS PB12NSD (X 2)
AVR: Yamaha Aventage RX-A2030
Blu Ray: Sony BDP-S790
TV Source: DirecTV Genie
Post edited by Loud & Clear on
  • recoveryone
    recoveryone Posts: 929
    edited April 2014
    I think his point is that he has it connected via Coax, which most SACD players require analog output.
    tonyb Posts: 33,068
    edited April 2014
    I believe when connected with coax, the SACD player uses a down mixed stereo signal. It may be better than what your used to, but it's not giving you the full benefit of SACD.
  • Loud & Clear
    edited April 2014
    tonyb wrote: »
    Is it passing 24/96? Whatever it's doing is pleasing to my ear. My only experience with SACD players are the Denon 2200, a few of the Sony BDP's, and an Oppo DV-980H. This downmix into DAC presentation is more lively and dynamic sounding. Details jump out and demand attention. I'm going to roll with it.
    Two Channel Setup:
    DAC: Arcam irDac
    Source: iMac
  • PolkieMan
    PolkieMan Posts: 2,446
    edited April 2014
    Most all of the higher model Sony Blu-ray Players will play SACD, the reason I selected Sony over the other brands.
  • Loud & Clear
    edited April 2014
    DSkip wrote: »
    To be fair, neither is that sony via analog.
    That's the point. If you don't have a nice SACD player but want to enjoy your SACDs, and have a blu ray player and decent DAC, you can use the method I'm using for better results. Maybe there aren't a lot of people who find themselves in a similar situation, but if they are they can experiment with this and hear for themselves. Oh, and to correct myself, it's the Sony BDP-S580, not S570. It's possible that they behave differently.
    Two Channel Setup:
    DAC: Arcam irDac
    Source: iMac
    SCompRacer Posts: 9,089
    edited April 2014
    SACD's copyright protection prohibits full resolution audio via S/PDIF. You are correct, it's dithered down PCM or LPCM. The L being quantization levels are linearly uniform where PCM quantization levels vary as a function of amplitude. Or something like that. Or they are the same. I'm buzzed ...lol
    avs forum has a huge thread on your player. Lots of pages, might be some grains of specifics in there for you.
  • Loud & Clear
    edited April 2014
    SCompRacer wrote: »
    Thanks. Figured you'd know the details within the details ;>).
    It's pleasing enough that I don't feel like I would need an HDMI input or DSD decoding capability when searching for a future DAC. Some type of readout would be nice, though. I'd like to be able to tell the bit rate and frequency that the DAC is receiving. Neither blu-ray player nor DAC will tell me what's being sent or received. How rude.
    Two Channel Setup:
    DAC: Arcam irDac
    Source: iMac
    edited April 2014
    Somebody knows, they just aren't tellin...lol
  • Loud & Clear
    edited April 2014
    Tried a DVD-A disc. Readout indicated the output was 24/96 LPCM. Next I'll try a 24/192 DVD-A disc and see what it says.
    When I played the SACDs, it just said "Two Channel DSD." But I'm guessing it just assumed that I was using the analog outputs instead of coaxial digital, so I don't know what it outputs via coaxial.
    Two Channel Setup:
    DAC: Arcam irDac
    Source: iMac
