HT rear speakers.
xjghost
I've been looking around for something to pair with my monitor 10's that are currently my mains in my HT system in my den. Space is an issue. I live in a small house. The only space I can put the rears would be on a wall above and behind the viewing area. They would practically be at the roof. I have ben toying with 7's and 5's. I came across some 5jr's on CL today. $80 seems like a decent price to me. I'll likely have to mount them horizontally because the wall is more of a divider. It only drops about a foot between the den and dining area. Does the horizontal vs vertical orientation matter? I'm new to Ht and this is my first attempt at putting together something. http://charlotte.craigslist.org/ele/4403514614.html
HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
Additional projects: RTA 12c's
Post edited by xjghost on
I think those will be excellent rears! As for side mounting, try it and see! I am something that is not nearly as picky about surrounds as mains and center, so my guess is you'll be fine. But if not you can resell them or even part them out and you won't lose any money, so I say go for it!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
I think you'll be fine mounting them horizontally. Your rear surrounds are not handling a majority of the sound and are there for ambiance. You've already done the most important thing and found speakers which are timbre-matched to your fronts, and even I'm not sold 100% on the need for that in rear surrounds (we'll see, I'm about to mount paradigms in my system).
Good luck!HT System:
Marantz NR-1403
Front: Klipsch CF-4
Rear: Paradigm Atom V3
Center: Boston Acoustic VR12
Sub: Bowers & Wilkins ASW600
2Ch:
Restored Fisher 500C
Yamaha P-500 Turntable
Living Room:
Harman Kardon 3380
Restored Polk Monitor 7B
Bedroom:
Harman Kardon VR-3750
Cambridge Soundworks Ensemble
Polk PSW10
In and out of rotation:
KLH Model 6,
Polk LSI7
NAD 7100
