Processor recommendations?
dagame27
dagame27 Posts: 599
edited March 2014 in Electronics
I'm looking for a processor as a go with my Anthem Pre 2l and Adcom 555, currently being used in a 2 channel system. I currently have a Harman Kardon receiver doing the job, but is has no HDMI. Any recommendations? The cheaper the better, but my max would be about $400 and used is fine.
ChrisIntegrated Amp: Cary SI-300D Processor: Marantz SR7012 Streaming: Bluesound Node 2I 4K Bluray: Panasonic UB820Mains: Von Schweikert VR2Center: Von Schweikert LCR15 Subs: 2 SVS Sb13 Ultra (HT Only) Analysis Plus Cables
Post edited by dagame27 on
    tonyb Posts: 33,072
    edited March 2014
    A current HT processor with HDMI...even a few years old....under 400 bones ? I think your stretching reality there my friend. Marantz would be the closest with some decent SQ....even Emotiva goes for more than that. You could however find a decent used receiver with HDMI in that price range.
  • dagame27
    dagame27 Posts: 599
    edited March 2014
    Tony, the receiver route was one I was thinking of; just wasn't sure if a HT processor w/ HDMI was a more attractive option.
  • unc2701
    unc2701 Posts: 3,587
    edited March 2014
    I'm also accepting the inevitable switch to HDMI. Onkyo PR-SC885 or Integra DHC 9.8, 9.9 are in that range; Integra 40.1, 40.2 have been known to go that low. They suffer from a HDMI board with caps that aren't rated for high temp & fail, but there's someone on ebay that repairs them for $75, so you can get a deal on broken ones that just need a quick fix.
    If they haven't failed, you can easily prevent issues by just putting a fan on it.
    Backburner:Krell KAV-300i
    tonyb Posts: 33,072
    edited March 2014
    dagame27 wrote: »
    Generally speaking a processor will offer up some better SQ along with greater tweeking ability. TOTL AVRs are getting close though too. If your priority is better sound, in a processor it will cost more than 4 bones, if the priority is HDMI.....that can easily be had for that coinage.
    Be careful of some older stuff with HDMI, some still won't process the newer blu-ray codecs.
    EndersShadow Posts: 17,704
    edited March 2014
    tonyb wrote: »
    Agreed. A Processor for 4 bones w/o HDMI is very easy. Add HDMI and your prob looking at 600+ easy if not 1k.
    Going with a AVR w/ pre-outs is a better solution, just be careful what your looking at. Accessories4less if your friend here IMHO and would look hard at their offerings.
    tonyb wrote: »
    If looking at HDMI, just make sure its HDMI 1.3 or 1.4 and your golden.
    As a total aside I have been debating upgrading from my Integra DTR 5.9 (which has 4 HDMI's) myself and if I do I will PM you and see if we cant work something out.
    tonyb Posts: 33,072
    edited March 2014
    Maybe he can offer you 4 bones for the Integra....plus a personally autographed life size pic of H9 ?
  • Gaara
    Gaara Posts: 2,415
    edited March 2014
    Outlaw Audio 975 or Emotiva UMC-1/200. All three go for around that used.
