Driver for LS90
adam2434
adam2434 Posts: 995
edited April 2014 in Wanted (WTB) Classifieds
Just discovered that the surround has separated from the cone about 3" on one LS90 driver. The adhesive failed.
It probably could be re-glued, but I assume the entire surround would need to be removed to do it right.
Anyone have a LS90 driver?
5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
Kitchen: Sonos Play5.
Post edited by adam2434 on
  • ken brydson
    ken brydson Posts: 9,015
    edited March 2014
    Polk still stocks them. $48 ea IIRC and free shipping if you mention you're a forum member.
  • adam2434
    adam2434 Posts: 995
    edited March 2014
    Just went ahead and ordered 2 replacements so I can have them mirrored on both speakers.
    CP discounted price is $60.
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited April 2014
    Did Polk raise the price on these?
  • I noticed today that the surround has separated from another woofer cone due to adhesive failure. I assume the surround could be completely removed and re-glued, similar to re-foaming a woofer. The surround easily peels away from the cone and frame. Polk's method of adhering the surrounds was not very robust on these woofers. I assume it's a matter of time before they all fail.
  • quickr1
    quickr1 Posts: 414
    sorry to hear that they came unglued again. if your looking for replacements there is a set for sale in the classifieds section.
  • Polk says they will repair the 2 drivers with the surround adhesive failure.
    Polk CS comes through again!
    pitdogg2 Posts: 27,201
    no that's a "Happy Ending"
  • adam2434
    adam2434 Posts: 995
    Got the repaired drivers back a couple days ago. Big thanks to Gary and Freeman in Polk CS!
    They look very nice. Both the surrounds and dustcaps were re-glued.
    The suspension is very stiff on the repaired drivers compared to non-repaired. Not sure why re-gluing the surrounds and dustcaps would make the suspensions so stiff. I always assumed that the spider and surround properties determine the suspension stiffness, and those did not change with the re-gluing.
    F1nut Posts: 51,920
    They probably installed new surrounds, hence the stiffness.
  • adam2434
    adam2434 Posts: 995
    F1, that may be true.
    After closer inspection, the surrounds do look "newer" than the ones on the other original drivers. I originally figured that they just cleaned and reused the original surrounds.
    I think Freeman also used different cones, as the cones look more like the ones in my MW7010 replacement drivers. Hell, he might have even reglued or replaced the spider too. They have a strong odor, adhesive I presume, that reminds me of Windex.
    It's surprising to me that Polk would have individual surrounds, cones, and perhaps even spiders available as "parts", when they also sell full replacement drivers. Very cool that they have the capability and talent to repair 20+ year old drivers. That has to be rare in this industry.
