Polk Audio SDA 2 Crossover Modification Thread
VR3
VR3 Posts: 29,551
edited April 2014 in DIY, Mods & Tweaks
Clarity Cap ESA, Jantzen Inductors, Mundorf Mox Resistors, Supra Rondo Internal Wire + Gold Disconnects, New binding post. Converted fuse holder location to house the NL4 connector, new NL4 SDA cable.
PTP Wiring, Delrin substrate
Post edited by VR3 on
  • villian
    villian Posts: 412
    edited March 2014
    Interesting
    Too many good quotes to list..waiting for some fresh ammo. :)
  • drumminman
    drumminman Posts: 3,396
    edited March 2014
    As usual, nice work Trey. What are the specs on the Rondo wire?
  • zingo
    zingo Posts: 11,258
    edited March 2014
    Those aren't Polk drivers...
    VR3 Posts: 29,551
    edited March 2014
    Thanks guys!
    2 x 2.5mm (13AWG)
    SUPRA Concentric Cables are highly flexible and of short pitch twisting for low inductance and low radiation as well as a high tolerance to frequent bending and vibrations before bending fatigue. This short pitch twisting takes special machines and is a slower and more expensive production which you do not often find in other than the Supra portfolio.
    Rondo wire is a good choice for all high end speaker applications, both external and internal wiring, hi-fi or stage.
    Heat and aging resistant PVC jacket
    2 conductor, 320 strands of 0.1mm wire
    Tin plated OFC
    External Size: 7.7mm diameter
    6.8 ohm per kilometer (3280 ft)
    0.4 microhenries per meter
    Those are actually limited run, kryptonian magnet equipped woofer. Pre "Bozo" model prototypes.
    VR3 Posts: 29,551
    edited April 2014
    I guess I did not realize I had to specify that the drivers pictured are for test purposes only and are not part of mod...
    *face palm* Sad day on the Polk forum.
  • BKphoto
    BKphoto Posts: 409
    edited April 2014
    nice carpet...
    oh yeah....great work, as always
    Marantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's
    VR3 Posts: 29,551
    10 year difference!
