Polk Audio SDA 2 Crossover Modification Thread
VR3
Clarity Cap ESA, Jantzen Inductors, Mundorf Mox Resistors, Supra Rondo Internal Wire + Gold Disconnects, New binding post. Converted fuse holder location to house the NL4 connector, new NL4 SDA cable.
PTP Wiring, Delrin substrate
As usual, nice work Trey. What are the specs on the Rondo wire?"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
Thanks guys!
2 x 2.5mm (13AWG)
SUPRA Concentric Cables are highly flexible and of short pitch twisting for low inductance and low radiation as well as a high tolerance to frequent bending and vibrations before bending fatigue. This short pitch twisting takes special machines and is a slower and more expensive production which you do not often find in other than the Supra portfolio.
Rondo wire is a good choice for all high end speaker applications, both external and internal wiring, hi-fi or stage.
Heat and aging resistant PVC jacket
2 conductor, 320 strands of 0.1mm wire
Tin plated OFC
External Size: 7.7mm diameter
6.8 ohm per kilometer (3280 ft)
0.4 microhenries per meter
Those are actually limited run, kryptonian magnet equipped woofer. Pre "Bozo" model prototypes.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I guess I did not realize I had to specify that the drivers pictured are for test purposes only and are not part of mod...
*face palm* Sad day on the Polk forum.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
nice carpet...
oh yeah....great work, as alwaysMarantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's -
10 year difference!
